new here need help
Old Jun 13, 2007 | 01:42 AM
neonsxt85's Avatar
neonsxt85
Default new here need help
i have 04 neon sxt 2.0 16valve and im wondering wat i should get to make it go faster. Should i buy 2.4 srt4 motor . can i get turbo kit to put it on... i wanna make it fast
Old Jun 13, 2007 | 05:13 AM
03neonRT's Avatar
03neonRT
Default RE: new here need help
Check out these two threads, has all the information you'll ever need. If you do have any questions though, feel free to PM me or ask in the 2nd Gen Neon section.
https://dodgeforum.com/m_540330/tm.htm
https://dodgeforum.com/m_665840/tm.htm
Old Jun 14, 2007 | 02:52 AM
neonsxt85's Avatar
neonsxt85
i have an automatic sxt tho...but what i can see the turbos are alot of money that i can just buy an srt4 motor for the same price or alittle less then.
Old Jun 14, 2007 | 06:36 PM
AirWolf's Avatar
AirWolf
If you have an auto than I would check out the hahn turbos they are the best for any yr automatic and they are new and run about 2500 to 3500 you might check on ebay also .
Old Jun 14, 2007 | 08:14 PM
neonsxt85's Avatar
neonsxt85
they run over 4grand. i basiclly can get whole new engine for that price. If anyone has a usedturbo kit for sale let me know ..
Old Jun 14, 2007 | 09:32 PM
AirWolf's Avatar
AirWolf
Used is most of the time not good . used are usually beaten to death. New at least for me is the only way to go and my stage 2 hahn turbo kit in my 96 has as much hp as a stock srt4 about 230 hp.
Old Jun 15, 2007 | 12:11 AM
03neonRT's Avatar
03neonRT
You can build a brand new 2.4l SRT-4 engine for around $3,000 if you really do the work and shop around for the best prices ...then spend another $1,000 on a used (but low mileage) transmission, buy a used wiring harness, PCM, and any other random parts you may need for the swap for a few hundred and your all set.
Old Jun 15, 2007 | 04:42 AM
lblackneon's Avatar
lblackneon
Forget the Hahn turbo kit and consider an SRT-4 motor with trans. The regular Neons internal engine components are only meant to handle around 250 hp max. The SRT-4 motors can handle way more so u wouldn't have to worry about internal engine components if u wanted to add even more performance. I wish I would have done the SRT-4 swap from the beginning. For the amount of money u would pay for a turbo kit u might as well do the SRT-4 swap.
Old Jun 15, 2007 | 04:30 PM
AirWolf's Avatar
AirWolf
With a hahn turbo kit its new and with a srt4 turbo good luck at finding a decent not abused engine and tranny . The hahn is the best turbo kit for an auto anyways and better in the long run.
