Crankshaft Sensor
Old Jun 16, 2007 | 08:26 PM
2kneon's Avatar
2kneon
Default Crankshaft Sensor
Hey, Im working on engine swapping, 2.0 for 2.0. I got my old engine out and started swapping parts over to the new engine, on the new engine i noticed there is no place for the crankshaft sensor that was on my old engine. What do I do?
Old Jun 17, 2007 | 12:40 AM
tooslow's Avatar
tooslow
Default RE: Crankshaft Sensor
caps what year you swaping because a 03+ motor wont swap into a pre 03 car and vice versa. With out a ton of modifications.. but the crank senser on a 03+ motor is right under the the starter
Old Jun 17, 2007 | 08:56 PM
2kneon's Avatar
2kneon
ive got a 2000 neon and putting a 2000 neon motor in it. the sensor is right above the oil filter. my old engine has it and my new one doesn'. im thinking about just taking the engine to a shop and have them bore out the hole for it.
Old Jun 17, 2007 | 09:01 PM
nswap7's Avatar
nswap7
whats the diff in the engine, cuz that doesnt make too much sense(to me) why one would have it but the other does.
Old Jun 17, 2007 | 09:06 PM
2kneon's Avatar
2kneon
thats what i thought too. when i ordered it i ordered the engine without the egr port. im not sure if my original had the egr, i did my research adn figured that it didnt have and egr port cuz i read that they arent in most cars
Old Jun 17, 2007 | 10:10 PM
nswap7's Avatar
nswap7
eh, well i dont know much about that, but i think having them basically delete the hole would be smart
Old Nov 22, 2008 | 06:44 PM
unykue's Avatar
unykue
Exclamation New user help!!!!
I have an 03 dodge neon, engine 2.0. Sometimes it'll start right up, and sometimes it takes a few seconds! Like many problems we all have...i need help to try and fix this issue myself. I put a new battery, coil pack, and spark plugs in it. I took it to a mechanic and it is the cam and crank sensor. If anyone knows how to replace these parts....
Please tell me how!!!!!!!!
I know where nothing is located....
Old Nov 23, 2008 | 12:36 AM
darthroush's Avatar
darthroush
Section Moderator
Sounds like you didn't get the same engine...
