short shifter question
Old Jul 6, 2007 | 05:04 PM
metsj373's Avatar
metsj373
Default short shifter question
does anyone know a site where i can buy a short shifter for a 2004 neon R/T
Old Jul 6, 2007 | 06:11 PM
03neonRT's Avatar
03neonRT
Default RE: short shifter question
www.MaddogSTS.com
^^Best short shifters on the planet. I have the 72% reduction and its amazing!
Old Jul 6, 2007 | 08:26 PM
Exubus's Avatar
Exubus
ORIGINAL: 03neonRT
www.MaddogSTS.com
Has anyone else here ever just cut some length off the stock shifter, replaced the bushings, and put an aftermarket **** on it? Leverage-wise (and physics-wise)it seems to me that the throw and feel would work out the same... just curious if anyone ever tried that and an aftermarket short-throw and noticed a difference.
Old Jul 6, 2007 | 10:27 PM
contagious19's Avatar
contagious19
i was going to get a megan racin short shifter for mine but it wont fit wen i do da swap
Old Jul 7, 2007 | 12:32 PM
03neonRT's Avatar
03neonRT
ORIGINAL: ptschafer
ORIGINAL: 03neonRT
www.MaddogSTS.com
Its more based on the shifter geometry, not so much the actual leverage of the rod/****. On the rod style aftermarket STS's for example, they are generally 1" shorter compared to stock, and give a 30% left to right throw reduction, and no throw reduction from front to back. On the otherhand, an entire STS assembly such as the Mopar (30%), Mopure (50%), and Maddog (50%, 72%, 80%)have actually changed the shifter geometry to reduce the throw in every direction up to 80% (Maddog). Harder bushings wouldnt shorten the throw either, they are designed to eliminate or reduce the play in the shifter cables on the assembly side and transmission side.
ORIGINAL: contagious19
If your talking about the SRT-4 swap...we use the same shifters they do. But dont waste your money on a rod style STS, becuase that only shortens the throw left to right, not front to back.
Old Jul 8, 2007 | 01:51 AM
metsj373's Avatar
metsj373
i got a mopar short throw ****fter is that good or should i return it and get a maddog and have the option of easily returning it
Old Jul 8, 2007 | 02:26 AM
03neonRT's Avatar
03neonRT
I had the Mopar for a little over a year before I switched to the shorter 72% Maddog STS so it is a great STS overall.
Old Jul 10, 2007 | 01:45 PM
metsj373's Avatar
metsj373
do u think i should sell the mopar shifter
Old Jul 10, 2007 | 01:53 PM
03neonRT's Avatar
03neonRT
If you want a shorter throw then sell the Mopar and by a Maddog.
