fuel
Old Jul 12, 2007 | 09:26 AM
blazing03neonR/T's Avatar
blazing03neonR/T
Default fuel
what is the best octane to run in the rtshould i stay with 87 or go up
Old Jul 12, 2007 | 10:59 AM
05SXT_Owner's Avatar
05SXT_Owner
Default RE: fuel
I've been told repeatedly that you should stay with 87 octane or 89 at the highest. 93 doesn't do any good for the neon.
Old Jul 12, 2007 | 12:08 PM
antitrustspider's Avatar
antitrustspider
Default RE: fuel
89 should be fine. High octane fuel is what they use for high compression engines, which yours is probably not, unless it's heavily modified.
Old Jul 12, 2007 | 12:20 PM
lblackneon's Avatar
lblackneon
Default RE: fuel
I've been told to stay with 87 on the regular Neons. Anything higher would be too rich. I'm not sure about the RTs but I would think they would be the same.
Old Jul 12, 2007 | 12:24 PM
l_pillon's Avatar
l_pillon
Default RE: fuel
ur just wasting octane which is just goin up in the atmosphere...my bro has a turbo jetta and his is almost 200hp and in his manual hes only suppose to use 89....ull be fine with 87
Old Jul 12, 2007 | 01:27 PM
03neonRT's Avatar
03neonRT
Default RE: fuel
On an R/T you should run Premium. On a base Neon you should run 87.
Old Jul 12, 2007 | 02:22 PM
blazing03neonR/T
Default RE: fuel
Thank you
Old Jul 12, 2007 | 02:30 PM
03neonRT's Avatar
03neonRT
Default RE: fuel
No problem.
Old Jul 12, 2007 | 10:03 PM
yellowO3r/t's Avatar
yellowO3r/t
Default RE: fuel
yep i've always used premium on my r/t
Old Jul 12, 2007 | 10:15 PM
AirWolf's Avatar
AirWolf
Default RE: fuel
I thought you only use premium on turbos and supercharged rides though or v8s like stangs and rides like that.
