Performance Upgrade questions
Rear disc conversion would probably be A good swap once you factor in the clearance of the knuckle for wider rubber. Them SRT boy are stuffing 225 and 235 tires up in there.
ORIGINAL: ewetho
ORIGINAL: GrApHite03
1, you missed my point... drums in the rear are lighter then neon or SRT rear brake set-ups. 2, why would you want wider tires in the rear?
ORIGINAL: ewetho
As for rear discs and larger front discs being "worthless", I'll let every single performance automaker in the world know that their wasting their time and money on rear discs and bigger brakes...
If your concerened about weight, the knucles and hubs weigh the same both front and rear regardless of how big the rotors are or whether you have discs, so why not just buy lightweight performance rotors?
you also missed my point....
Think how you like... I will not put SRT disc brakes on my neon. My drums in the rear are lighter than other OEM disk set-up whether it be R/T or SRT. Also, as i already mentioned... My front disc set-up is lighter than any OEM set-up that will swap on my car.
We do not own race cars... i doubt anybody here is even close to pushing 150hp with the execption of what... 2 maybe. When people ask how to make there car faster i refuse to help them put heavier equipment on thier car to make them slower.
We are not talking about aftermarket big brake set-up that are engineered and desinged to be bigger an lighter. No where in this thread was an aftermarket big brake kit mentioned. Next time you want to put words in my mouth at least ask first...
k3v
k3v
thats a good list even for a NGC... Those are all things the computer cannot account for or control.
also, SRT brakes are worthless... just like rear disc conversions. why add more weight to the car? I know SRT guys that have downgraded to non-srt brakes for that reason. weight reduction
ORIGINAL: ewetho
For the pre-NGC cars that list is good. Probably go with UDP and ThrottleBody for just bolt-ons.
As for wheels, probably stick with 15" just for wider selection of rubber.
Think it is moder that has some uber lite Rotas that are plenty wide for serious rubber for when you finally do your SRT brake swap to stop this thing.
cams
port and polished head
port and polished intake manifold
bigger throttle body
udp
50 shot (wet)
weight reduction
smaller/lighter wheels (14's)
cams
udp
50 shot (wet)
weight reduction
Plus, anything that will increase airflow (for N/A OR turbo work) will help with power.
Also, you mentioned a supercharger in your first post.
No such thing exists for neons Yakuza.
Vortech has a supercharger for da neon. http://www.andysautosport.com/dodge/..._kits/vortech/
ORIGINAL: neon03se
i do also feel likei lose power when i have the A/C on, also when i go into WOT, or maybe its just all in my head
ORIGINAL: Biged83
not sure about that. i know mine kills my power. and when i go wot the car just doesnt want to go. i know i need a tune up but i still think the ac robs alot of power (hence the reason i dont use it)
ORIGINAL: spikeymikey87
no need to lose the a/c it doesnt rob that much power. actually, if you have it on and you go into WOT, it will shut off and you wont lose any power from it
ORIGINAL: contagious19
ORIGINAL: Yakuza
Whats WOT mean?
ORIGINAL: neon03se
ORIGINAL: Biged83
And someone answer this for me, if the SRT-4 brakes, and rear discs in general are worthless, then how is it the SRT-4 has a 60-0 braking distance of 117 feet, the R/T of 120 feet, and the Neon without rear discs of 135 feet?
I'm not going to argue with you... yes your facts are right.
How many people here are worried about braking? The OP asked about going faster... What good is 18 feet when it takes you longer to get to 60mph.Thats a trade off that is not worth(less) it to me. My statement still stands, you ask me how to go faster i will tell you. I will not give you suggestion that will slow you down, unless you ask.
It cracks me up... most of the guys asking how to go faster are in another thread talking about there 12" subs they just put in the trunk. :shakes head:
k3v
k3v
Fair enough
I'll weigh the stock front Neon knuckles/calipers/rotors and compare them to the weight of the SRT front knucles/calipers/rotors and see what the difference is so everyone knows...
.I'll weigh the stock front Neon knuckles/calipers/rotors and compare them to the weight of the SRT front knucles/calipers/rotors and see what the difference is so everyone knows...
