whats the problem
Old Jul 17, 2007 | 11:15 PM
20NeonSXT04's Avatar
20NeonSXT04
Default whats the problem
When I try to go to second gear SOMETIMES not ALWAYS I hear the nasty grinding sound , and I know its not me because I have held the clutch down and have shifted gears while idling and it does it , is it Trans or clutch problem...
Old Jul 18, 2007 | 07:01 PM
20NeonSXT04
Default RE: whats the problem
anyone..?
Old Jul 18, 2007 | 08:21 PM
spikeymikey87's Avatar
spikeymikey87
how many miles on the clutch
Old Jul 18, 2007 | 10:42 PM
2003SXTneon's Avatar
2003SXTneon
lately my clutch has been kinda doing that. mines alittle diff. though: when i try to down shift to gain more speed sometime it wont go in at all, untill i slow down to a certain speed. its like it has a lockout or something.
Old Jul 19, 2007 | 05:28 AM
20NeonSXT04
Iam pretty sure it has the stock clutch , if so 59 k
Old Jul 21, 2007 | 03:28 AM
I own only Dodge's Avatar
I own only Dodge
Sounds to me like your synchronizers may be worn out.
Old Jul 21, 2007 | 04:07 AM
j_son600's Avatar
j_son600
I would second the synchronizer, my first gen probe has a bad synchro on first and anything other than a complete stop it will grind. From what I hear a synchro is a pain to replace, good luck.
Old Jul 31, 2007 | 10:41 PM
I own only Dodge
A little tip, if you drive with your hand on the shifter it will put a slight strain on the synchronizers and cause them to wear prematurely. I know I did that an old Dodge truck I had. Let us know what you find out on it, I'm curious
