srt transmission
Old Aug 4, 2007 | 09:34 PM
redbirdhky6's Avatar
redbirdhky6
Default srt transmission
does anybody know if the srt-4 transmission will bolt up to the 2001 R/T motor?
Old Aug 5, 2007 | 12:17 AM
GrApHite03's Avatar
GrApHite03
Default RE: srt transmission
it'll bolt up to the motor, but getting it to fit and work may be a little harder...
Old Aug 5, 2007 | 04:03 PM
redbirdhky6
i figured puttin it in would suck tryin to get it around the K frame. but as long as i get it in it will work right?
Old Aug 5, 2007 | 04:04 PM
03neonRT's Avatar
03neonRT
Yes.
Old Aug 5, 2007 | 04:19 PM
redbirdhky6
decent cause my 3rd gear is giving me problems and when i took it to the transmission shop the quote was $1600 and a guy i know will install a srt tranny with 900 miles on it for only $500.
Old Aug 5, 2007 | 04:33 PM
GrApHite03's Avatar
GrApHite03
You will have to modify the K frame to get it in... You will have to use SRT axles which leaves with a situation. The jack shaft bearing bolts to the 2.4l block very nicely. Unfortunately it will not bolt to the 2.0l. The shop is going to have to fab up a custom bracket in order for the bearing assembly to fit. ope your shop is good, if that bearing placement isn't true i can see alot of bearing replacements in your future.
There is also possibility that the placement of the tranny may make it difficult to lower the car.
There is a thread on 2gn.org where someone says they did it... I'm pretty sure everybody came to the conclusion that the original poster was full of ****. They would not provide proof that the tranny was in or any type of video of it running. I've yet to hear of anybody successfully doing it yet.
ORIGINAL: redbirdhky6
If its an 03 tranny its not worth it... It'll just add weight and make your car slower.
k3v
Old Aug 5, 2007 | 06:22 PM
redbirdhky6
well is it not going to work then since mycar is already lowered? what has to be done to the K frame? hes also got just a base neon tranny but im makin too much power for that to last
Old Aug 5, 2007 | 06:52 PM
GrApHite03's Avatar
GrApHite03
i've seen 400+ handled on a 2.0l MTX tranny...
Old Aug 5, 2007 | 07:09 PM
redbirdhky6
well then i guess im not makin too much power, but still i need to know if i can use the srt tranny in my 2.0
Old Aug 5, 2007 | 07:29 PM
GrApHite03's Avatar
GrApHite03
that question has already been answered
