r/t motor swap
Old Aug 10, 2007 | 04:26 PM
contagious19's Avatar
contagious19
Default r/t motor swap
i was thinking, if i do a r/t swap, instead of a srt-4 swap. would it be easier.?
Old Aug 10, 2007 | 04:35 PM
Adionik's Avatar
Adionik
Default RE: r/t motor swap
uh....
i don't think the gains are worth the hassle...but the r/t i would imagine would be easier.
srt swap would give you a huge booooost in your performance
Old Aug 10, 2007 | 04:38 PM
contagious19
ORIGINAL: Adionik
uh....
i kno, but if i do a r/t swap i could turbo it wit extra money i would have extra and i believe a stock r/t can hold more psi dan a stock se
AirWolf's Avatar
AirWolf
You can also do the pt cruiser turbo swap same motor as the srt4 and alot cheaper and more simple to do overall.
Old Aug 10, 2007 | 04:42 PM
Adionik's Avatar
Adionik
Yes, but nothing will compare to a factory turbo'd SRT engine that was designed to take the pressure of a good turbo system.
It would be a lot safer and reliable to do the srt swap if your eventual plans are forced induction.
contagious19
yea but i dont want to deal wit da hassle like fuel pump and all dat stuff at one point. like if i do a r/t swap stock and then turbo it and i believe would be less time and easier
Old Aug 10, 2007 | 05:41 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: AirWolf
If you do go this route, you need to buy an SRT-4 intake manifold, TB, and cold side pipe.
Also the R/T's bottom end is no different than a SE/SXT... so it won't hold more power. Only dif is intake/exaust manifolds, head, cam, & ECU. And with all that you'll only see a 20hp gain
k3v
Old Aug 10, 2007 | 06:31 PM
contagious19
so bottom end is just like se. damn but some reason i wan to go dis way. r/t swap and den turbo yay or nay
Old Aug 10, 2007 | 06:35 PM
GrApHite03's Avatar
GrApHite03
i swapped the head and cam, since the head flows better and the cam is comparable to a crane 10. It can be done on the R/T ECU but with the extra timing advance i didn't want to push my luck.
Old Aug 10, 2007 | 06:37 PM
antitrustspider's Avatar
antitrustspider
Just trade your car in for an SRT-4. Problem solved.
