bore and stroke and custom strokers
Old Aug 18, 2007 | 09:04 PM
SXTspeed's Avatar
SXTspeed
Default bore and stroke and custom strokers
I am sure increasing the bore and stroke of a neon's 2.0L engine is possible but has anybody done it? What about getting a stroker motor or making one yourself? Could you get a stroker crank and build a stroker like you would for a muscle car?
Old Aug 19, 2007 | 01:27 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: bore and stroke and custom strokers
howell sells a stroker crank. and you have to bore the motor if you want .020 over pistons lol. i will be doing that for my new motor
Old Aug 19, 2007 | 07:50 PM
I own only Dodge's Avatar
I own only Dodge
Well pretty much isnt that all the srt 2.4 is a bored 2.0 block?
Old Aug 20, 2007 | 12:55 AM
contagious19's Avatar
contagious19
ima bore mine since im going all motor
Old Aug 20, 2007 | 01:05 AM
spikeymikey87
srt is not close to a bored 2.0 its a different block
Old Aug 20, 2007 | 02:24 AM
03neonRT's Avatar
03neonRT
While the 2.4 and 2.0 blocks are very very similar, the 2.4 still cant be described as a bored 2.0...
Old Aug 20, 2007 | 10:44 AM
SXTspeed's Avatar
SXTspeed
I looked at Howell and their kits are good for a 2.2L stroker. So it isn't quite as good as an SRT-4 but i'm sure it would have noticable impovements over the stock 2.0L. I also looked at DCR and they have srt-4 strokers, I would if those would work on our neons. I believe they are 2.6L.
Old Aug 20, 2007 | 06:04 PM
tooslow's Avatar
tooslow
the 2.4 and 2.0 has the same bore I think it is 87mm.
