my day off
Old Sep 3, 2007 | 12:19 AM
Mike594sxt's Avatar
Mike594sxt
Default RE: my day off
I got that same strut bar from ebay too. Was thinking about painting it blue or red.
Old Sep 3, 2007 | 12:37 AM
Kalevra's Avatar
Kalevra
nice. I was thinking about painting mine... but idk
Old Sep 3, 2007 | 10:54 AM
Mike594sxt's Avatar
Mike594sxt
Go over it with some sand paper and steel wool. Then hit with a coat or two of gray or white primer. Then do like 3 coats of a high-gloss enamel, that specifically is for metal, and you'd be set. Wouldnt peel or fade or anything. Gotta really let it dry though, in between coats.
Old Sep 3, 2007 | 10:45 PM
AirWolf's Avatar
AirWolf
You had the same idea as me . I already painted my fusebox cover and intake red and a few more things inside. I think Im going to paint my strut bar red also.
Old Sep 4, 2007 | 06:10 AM
Yako's Avatar
Yako
hey airwolf hadnt been here in a while anyway how u reoilthe k&n filter?
Old Sep 4, 2007 | 10:18 AM
ricerchik02's Avatar
ricerchik02
Ha, I did the same thing on my days off. I didn't paint the same parts tho, just painted some interior panels and my front bumper. It was scratched and horrible looking, lol. Ur paint job looks good tho, I like it!
Old Sep 4, 2007 | 10:25 AM
AirWolf's Avatar
AirWolf
ORIGINAL: Yako
with the recharger stuff and oil that comes in the package you can buy at any autoparts store. I think it cost me around 20 to 30 bucks.
Old Sep 4, 2007 | 01:36 PM
contagious19's Avatar
contagious19
i have da same strut bar also, u have to adjust de endlinks to make it fit. and da recharge oil thing, its like 12 bucks at autozone. and im goin to paint some more interior tomorrow. i need more paint.
Old Sep 4, 2007 | 01:39 PM
Kalevra's Avatar
Kalevra
Cleaning a K&N filter steps
1. knock and brush off any surface debris
2. spray on K&N air filter cleaner and let set for 10 minutes
3. wash the filter with low pressure tap water from the clean side to the dirty side (from the inside of the filter to the outside)
4. shake out/tap out remaining water and let dry throughly
5. Oil filter with K&N filter oil along the filter pleats only once using the correct amount of oil as per your filter specifications (found in the directions or on the K&N site) and let oil soak into the wicks (pleats) for 20 minutes
6. if any white spots (un oiled spots) are visible touch up and let dry for 20 minutes
7. wipe excess oil from gaskets and seals on the filter. if after 20 minutes oil drips from the filter medium then start over from step 1
Caution: Over oiling filter may interfere with engine performance and operation. refer to filter specifications for proper oiling amount.
If i left out anything, let me know
Old Sep 5, 2007 | 10:44 AM
AirWolf's Avatar
AirWolf
ORIGINAL: Kalevra
Sounds exactually right . I havent had my k&n on for awhile I have a custom cf fliter I use for shows and its nicer than my K&n fliter by far and still get whatI got out of the k&n.
