Before I go to the mechanic... Thermostat?
Old Sep 5, 2007 | 06:30 PM
tronkity's Avatar
tronkity
Default RE: Before I go to the mechanic... Thermostat?
I'm going to try boiling my thermostat when i get home. That's a great idea. Now I just need to figure out where the darn thermo is on the neon. haha
I checked the oil and it's not milky or smelling like coolant so that's good.
Old Sep 5, 2007 | 08:11 PM
bone33's Avatar
bone33
ORIGINAL: tronkity
Its housed just below the filler neck and are held in with two bolts. Remove the two bolts and the housing will pop off. You'll get a new O ring with the new thermostat so be sure to use it. There is a vent on the thermostat that has to line up with a notch on the cylinder head. If you don't line it up, it will not work correctly.
Old Sep 5, 2007 | 08:14 PM
contagious19's Avatar
contagious19
ORIGINAL: bone33
ORIGINAL: tronkity
+1
Old Sep 5, 2007 | 08:20 PM
ek2588's Avatar
ek2588
Just a lil side note to the boiling thing. The thermostat is suppose to contract at a certain temp tho (i want to say 180 degressF.but that might be something else) if it doesnt then that means it needs to be replaced
Old Sep 6, 2007 | 12:23 PM
tronkity's Avatar
tronkity
I read up on the thermostat last night. it is supposed to go at 140 degrees. the car is at the mechanic now. I just hope they diagnose it properly. I took it to another mechanic the other day and they said the radiator was blown and it would cost me $2000 to have it fixed. HAHA . I think they were just saying that because I'm a girl. I told them I'm going for a second opinion. I'll let you guys know whats going on when I get a call from the mechanic. I was scouring the internet the other day looking for advice on this problem and didn't find much until I stumbled upon the forum.
Old Sep 6, 2007 | 03:01 PM
NHARINTON's Avatar
NHARINTON
just replace it and see if thats it..... their only like 10 bucks!
Old Sep 7, 2007 | 12:36 PM
tronkity's Avatar
tronkity
Ok so my neon is fixed.
We replaced the thermostat and took it for a drive and the gauge was still spiking. Boyfriend put the car in the air to look at the wiring... there was a stripped wire. That was the problem. It's all fixed now and has a new thermostat and got the radiator flushed. Yay!!! Now I can go to Vegas!
Old Sep 7, 2007 | 04:20 PM
contagious19
congrats
