Just Bought A 2005 Dodge Neon SXT
Old Sep 6, 2007 | 09:52 PM
Twan's Avatar
Twan
Default Just Bought A 2005 Dodge Neon SXT
Hey everyone. I just bought an '05 SXT for $12,000 from Carmax. It only has 16,000 miles on it! It's silver. Anyways, I got a few questions.
1) I assume those are 15-in. wheels? I am looking to buy a set of rims. What would the junkyard pay for my old rims once I get the new ones?
2) What exactly is the purpose of an upgraded exhaust system? How hard are these to install?
3) Does it damage my car when I rev it in P? What about when I'm in N?
4) Does this car have some sort of ultra sound system? The bass sounds so good, I don't even know if I'm going to need to buy those subwoofers.
5) What is the 0-60 on this?
6) How hard would it be to put a bumper on it? Something like http://static.zoovy.com/img/stage3mo...ia_kit_red.jpg (except on the Neon, of course) would look awesome.
7) Any suggestions you have?
Old Sep 6, 2007 | 10:20 PM
dodgeneonz's Avatar
dodgeneonz
Default RE: Just Bought A 2005 Dodge Neon SXT
I don't know all the answers to your question.. but I know a few
An upgraded exhaust system would increase your car by a few horsepower depending on how much you're modifying your exhaust... ex. catback, header, or just muffler. Also, some of them would give you a deeper rumble depending on the type of exhaust you get. If you upgrade your exhaust, you should upgrade your intake also... otherwise the intake would be restricted no matter how much you modify your exhaust. Some exhaust are bolt on while others require modification such as welding, etc. Unless you're getting a bolt on... otherwise be prepared to spend some money at the muffler store to have them install it. Although it's better to weld everything rather than bolt on.
When your rev in P it won't damage the engine because the ecu would come in when you reaches about 4,000rpm. In N, you could reach the redline and thus yes dont' let it go past the redline.
Um... i didn't think the bass was all that good... I upgraded the rear and front speakers and got a better sounding system from it. I used to have a 300w sub but it was blown... so I just live without one now... and the car's lighter
Putting a bumper on your car isn't that hard. If it's made specifically for the neon (direct bolt on/match) then it's easy... basically 3 screws underneath (inside the fender and a little hard to reach) on each side and some plastic put in clips in the front middle top. If you're just getting the lip kit then you'll need to do some drilling. Good luck on it
Old Sep 6, 2007 | 10:26 PM
Twan's Avatar
Twan
See, I like your front bumper. How much did that cost, did you do it yourself, and where did you buy it?
Old Sep 6, 2007 | 11:06 PM
contagious19's Avatar
contagious19
i believe he has a stock sxt bumber wit da mopar lip kit on,
Old Sep 6, 2007 | 11:07 PM
AirWolf's Avatar
AirWolf
His is the mopar lip kit and they are the most popular kit on here and pretty cheap and easy to put on . I can but one for 140 now they are going down where I live comes with front lip and r/t sides and rear bumper and cut outs for a dual exhaust. A nice dual exhaust would be a magnaflow or borla or even a srt exhaust with glasspack. For the sound system I would get 4ways and a amp and a nice headunit.
Old Sep 6, 2007 | 11:19 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Twan
A stock SXT has 15" wheels. A junk yard may throw you a couple bucks for the rims, you can also try selling them on Ebay or other Neon forums, but either way your not going to see any real return on them. Best bet is to keep them for winter...
The purpose is to have a more free flowing exhaust system. They arent difficult to install at all, and they can be done by the most amature of DIY mechanics in my opinion.
Yes, NEVER rev an automatic in Park or Neutral, you risk causing serious damage to your transmission by doing this.
The stock system is actually faily nice from the factory, sound system freaks would obviously disagree...
For a stock ATX Neon your looking at a 1/4 mile in the very high 16's, and the 0-60 probably around 8.5-9.0 seconds.
Installing a new bumper isnt difficult, nor is adding a lip kit such as the Mopar. To rremove the bumperrs you only need to remove several screws, if you ahve fog lights, disconnect the hookup, and your basically done.
Swap to an MTx, dont rev the engine, ask as many questions as you can think of, be smart when modding (goes along with asking lots of questions), and do as much research as possible when modding.
Old Sep 6, 2007 | 11:42 PM
Twan's Avatar
Twan
What's an MTx?
Old Sep 6, 2007 | 11:43 PM
03neonRT's Avatar
03neonRT
MTx = Manual Transaxle (Manual Transmission)
ATx = Automatic Transaxle (Auto Tansmission)
Old Sep 6, 2007 | 11:52 PM
Twan's Avatar
Twan
And can anyone be more specific on what a lip kit is (maybe before/after photos, how do I put a lip kit on?)
Old Sep 6, 2007 | 11:54 PM
03neonRT's Avatar
03neonRT
My car before the front lip kit (and a bunch of other stuff obviously):
And my car with the Mopar Lip Kit:
I hope that helps a little bit...
