Help with codes? One isn't even listed....
Old Sep 17, 2007 | 09:08 PM
snare_samn's Avatar
snare_samn
Default Help with codes? One isn't even listed....
My car is throwing these codes, in this order:
P1684- Driver 5 Line 4
P0122- Throttle Postion Sensor Circuit Low Voltage
P0123- Throttle Postion Sensor Circuit High Voltage
P0108- Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P1297- Not listed on this site
P0121- Throttle Position Sensor Circuit Insuffiecient Activity
P0137- HO2SCircuit Low Voltge Bank 1 Sensor 2
My car won't start most of the time, but when it does, it won't idle. I have to continually give it gas to stay on and a lot of gray and white smoke is coming from the engine bay and exhaust. But mainly, just some help figuring out what these codes mean would be nice. I couldn't find the 5th one and the rest just confuse me; it's like they contradict themselves. Thanks for any help.
Old Sep 17, 2007 | 10:28 PM
Mike594sxt's Avatar
Mike594sxt
Default RE: Help with codes? One isn't even listed....
Lmao, why don't you just take it to a shop or a dealership??? With all those codes and supposedly gray and white smoke, you'd be lucky if your car doesnt completely die in like a month. Theres a ton of stuff I could tell you, and a ton of stuff everyone else could tell you. But dont you think it would be easier just to take the car somewhere to get looked at?
Old Sep 17, 2007 | 10:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Code P1297 no change in map from start to run.
Old Sep 17, 2007 | 11:32 PM
snare_samn's Avatar
snare_samn
Aw, come on, I'm a broke college student. Is there anything that I can fix myself? I've got a few friends with decent car knowledge (one works at a Ford dealership) but they'll only come over and help me whenthey know exactly what they're going to do for the day.
Old Sep 18, 2007 | 12:12 AM
neon03se's Avatar
neon03se
i was throwing similar codes to that a while back but no smoke, all i did was check the connections to the ecu and one of them was loose, i'm not sure how it came loose but i put it back snugly and made sure it was connected right, reset the ecu, and haven't had those weird unlisted codes again.
Old Sep 18, 2007 | 12:14 AM
GrApHite03's Avatar
GrApHite03
ORIGINAL: snare_samn
what have you touched on the car lately?
Old Sep 18, 2007 | 03:15 PM
snare_samn's Avatar
snare_samn
I took it to a shop to fix a bent tie rod and it ran fine all day. It rained that night and the next morning, all the smoke, no starting, and CEL showed up.
Old Sep 18, 2007 | 10:01 PM
master tech
Okay. You ask for help on a code you couldn't find. Have your friend from the FORD dealer hook up the super star tester and ck you baro pressure ( map sensor ) If you know what your baro pressure is, that will tell you are out of specs and need a new map sensor. If its in specs then replace the TPS. The baro pressure here 29.9 hg.
