Whining
Old Oct 11, 2007 | 12:58 PM
sparky1_2007's Avatar
sparky1_2007
Default RE: Whining
my MTX has always had a distinct whine from it when my car was stock, but when i put in my exhaust, i havent heard it since, just my power steering pump is all ive heard.
Old Dec 8, 2012 | 10:13 PM
christurbo123's Avatar
christurbo123
2002 sxt whining noise, automatic, power steering fluid full ( does not whine worse when I steer car) tranny fluid looks good, only thing I can think of is water pump? belt tensioner? maybe alt. ? or the worst tranny? I suppose If I take belt off and run car I can rule out tranny and its still there it is tranny, unless its timing belt? Help please
Old Dec 9, 2012 | 01:42 PM
Moparkyle's Avatar
Moparkyle
It's normal for the timing belt to make that sort of noise.
Old Dec 11, 2012 | 02:42 PM
TejasMtnBiker's Avatar
TejasMtnBiker
either p.s pump or your alt.
If the alt bearing is the slightest bit dry it'll whine at high rpms, esp once it heats up. So if you take the belt off an can spin it by hand it should turn smooth as butter and completely quiet, since it's an older model you can take it apart to r&r the bearings, not suggested if this is your first alt. to open up though.
If it's under warranty but wont replace it for bearing whine, go to the car wash keep the car running and blast pressure water in the alt until the cel comes on Be sure to dry it good before taking it in for a swap
I don't recommend this but its not right when a dura-last alt bearing wasn't properly filled with grease way down in Mexico
