Squeeking Struts
Old Oct 12, 2007 | 06:49 AM
street and track's Avatar
street and track
Default RE: Squeeking Struts
my stuts do the same and all so make a knocking sound its been driving me mad am going to strip them down this weekend and see whats going on.
Old Oct 12, 2007 | 12:06 PM
Rodge57's Avatar
Rodge57
I fixed the problem today. The rubber bushing that connected to the A frame was rubbing together. Mine was doing it on both sides. I just took WD-40 and sprayed on the rubber. Fixed them both. So it wasnt the struts.
Old Nov 13, 2007 | 06:53 PM
street and track
i have stoped my from squeeking and baning i used wd-40 to stop the squeeking and it was the top of the rear struts had worn out happy days now lol
Old Nov 13, 2007 | 07:55 PM
TN.Frank's Avatar
TN.Frank
My wifes '99 Dodge Caravan recently had it's struts replaced at 100K miles and now it has a "squeek" in it. Didn't do it with the old, stock strutts but with teh new ones it does. Don't know if you could get something like an oil or grease around the area where it is making the noise or not. If someone figures this out I'd like to try the fix on the van.
Old Nov 13, 2007 | 08:26 PM
BDM's Avatar
BDM
I wish I knew where exactly to spray if that infact fixes it. I have the exact same symptoms as Rodge57. Can anyone help me out?
Old Nov 13, 2007 | 08:37 PM
Rodge57's Avatar
Rodge57
I will try to take some pics this week. Sorry I forgot!!
Old Nov 13, 2007 | 08:38 PM
03neonRT's Avatar
03neonRT
ORIGINAL: dodgeneonz
ok, i tried tightening everything... and they're tightened but it still didn't go away... so for me i'm just gonna turn my stereo up and ignore it
Clunking from the rear struts is pretty common when you install lowering springs and new struts. For whatever reason it makes the upper mounts make a clunking noise, the only solution I've seen is to fill the mounts with urethane...mine clunk with the Prokit and HP Blues, but I ahvent gotten around to fixing it yet.
