Squeeking Struts
Old Oct 9, 2007 | 06:22 AM
Rodge57's Avatar
Rodge57
Default Squeeking Struts
When I am driving in my 05 Neon SXT with under 35k miles on it and I am going at a low speed sometimes when I turn a curve I can hear a squeeking noise in the front end. Also when I go over a speed bump or anything that will make the car bounce a little I can hear it. I believe it's the sturts, is there anyway possible that I can make this stop? Has anyone else had this problem? My car sounds like it has 200k on it lol.
Old Oct 9, 2007 | 02:42 PM
GrApHite03's Avatar
GrApHite03
Default RE: Squeeking Struts
ORIGINAL: Rodge57
mine does the same... except mine is a 2001 with 39k on it. unfortunatly we bought neons and not bmw's.
I could be the way the spring is sitting in the perch, but who knows... I'm doing a complete bushing replacement around the end of next month. I'll let you know if that fixes anything.
k3v
Old Oct 9, 2007 | 05:16 PM
Kalevra's Avatar
Kalevra
I thought I had a squeek in my suspention, it turned out to be the ebay CAI rubbing on the metal around the hole of the fender XD promptly fixed it by repostioning the mounting bracket (it was one of the cheap brakets)
Old Oct 9, 2007 | 10:01 PM
Rodge57's Avatar
Rodge57
Will any oil work? Anyone know anything else?
Old Oct 9, 2007 | 11:11 PM
ewetho's Avatar
ewetho
05 with less than 36K let the dealer make it shut up.
Old Oct 10, 2007 | 10:59 AM
Rodge57's Avatar
Rodge57
Hmm Dealer will cover that?
Old Oct 10, 2007 | 06:46 PM
Rodge57's Avatar
Rodge57
HELP! This is killing me. Makes it sounds junky!!!!
Old Oct 10, 2007 | 09:42 PM
dodgeneonz's Avatar
dodgeneonz
yeah, mine had the same problem too after i replace stock with lowering springs and tokico... it's just a faint squeak right? I hear it whenever it's at night without much cars... I'm going back to retightened all the struts bolts soon... i'll let you guys know if that does anything.
Old Oct 10, 2007 | 10:05 PM
technical18's Avatar
technical18
when i did my lowering springs and tokico struts i oiled all the bolts wit wd-40 as i put them back on...mainly to make the nuts screw on easier but i dont have any squeaking
Old Oct 12, 2007 | 12:29 AM
dodgeneonz's Avatar
dodgeneonz
ok, i tried tightening everything... and they're tightened but it still didn't go away... so for me i'm just gonna turn my stereo up and ignore it
