i think i broke it
Old Oct 9, 2007 | 01:49 PM
noen_newbe's Avatar
noen_newbe
Default i think i broke it
ok so when i drive my car and im going above 65 or so the wheel starts to shake and vibrate and when i drive on curves i feel a clicking type vibratation i obviously dont know the correct word but can some one help me out?
also when ever i pull 1st to red line and shift into secound the car pulls to the right when i shift
i hope i didnt break somethign
Old Oct 9, 2007 | 01:55 PM
Freerider's Avatar
Freerider
Default RE: i think i broke it
check your lugz!!!
get a 4 way and make sure you tightened them down. if not check your suspension for rattling and looseness.
Old Oct 9, 2007 | 02:13 PM
NHARINTON's Avatar
NHARINTON
yeah get that car on a lift and check everything, caould be as little as a loose lugnut, or as bad as broken suspension. I know that broken cv boots will click then you turn..... might want to check those.
Old Oct 9, 2007 | 02:44 PM
noen_newbe's Avatar
noen_newbe
ok the only thing is that its not a click sound its a vibration but there is a pause between the vibration
it will go like ummm -----_-----_----_----_ the lines on the floor is the click does any one understand what im tring to say?
Old Oct 9, 2007 | 02:46 PM
Freerider's Avatar
Freerider
check your suspension out thouroughly. Take your wheels off, get back by the CV Joints and check to see if they have ruptured,check your suspension completely.
My .02
Old Oct 9, 2007 | 03:44 PM
Yako's Avatar
Yako
lugsand alignmet?
Old Oct 9, 2007 | 06:04 PM
Andpto's Avatar
Andpto
or a bad tie rod. This happen to me last month
Old Oct 9, 2007 | 10:38 PM
noen_newbe's Avatar
noen_newbe
well it all started when i drove like the dick i am and bottomed out and **** i wasnt going fast
Old Oct 10, 2007 | 01:52 AM
Mat00ES's Avatar
Mat00ES
I have the same problem, my passanger side tire rod is shot. At high speeds my wheel vibrates to all hell and it pops at the smallest turn. Im getting a new one tomorrow for $40, putting it on myself. I'd still check your lugs and stuff to be on the safe side.
Mat
Old Oct 11, 2007 | 02:11 PM
noen_newbe's Avatar
noen_newbe
well im going to pep boys or somthing to get my **** aligned and balanced
