jet chip
Old Oct 13, 2007 | 10:12 AM
pacmansxt04's Avatar
pacmansxt04
Default jet chip
has anyone tryed the jet hip at howelle automotive.com 4 a 2nd generation neon. how did it work out and did u fell a difference
Old Oct 13, 2007 | 10:33 AM
Yako's Avatar
Yako
Default RE: jet chip
Jet Chip Dodge Neon 03-05 Stage 1
90408
[align=left]
List Price $299.00
Your Price $239.95
Detailed Description
The JET Performance Module for Dodge, Chrysler and Jeep vehicles is a JET exclusive. Dynamic Spectrum Tuning provides power gains across the entire power band-not just at full throttle. Point by point air/fuel ratio, ignition advance and various other tuning points provide performance gains of up to 25 horsepower. Improves throttle response, acceleration and low end torque. Simple, plug-in installation in less than 30 minutes. Available in Stage 1 and Stage 2.
Stage 1-For stock or mildly modified vehicles. Fuel and timing curves are modified for optimal performance and mileage using less expensive, lower octane fuels. Programming is designed to burn fuel at peak efficiency, which results in improved performance and mileage. Daily drivers can use lower cost regular fuel for potential mileage gains, but for optimal performance gains use of mid-grade or better is recommended.
pricey... i wouldnt trust it[/align]
Old Oct 13, 2007 | 11:08 AM
pacmansxt04
i want 2 give it a shot but im looking 2 c if anybody has tryed it out
Old Oct 13, 2007 | 11:32 AM
LowSlowNeon's Avatar
LowSlowNeon
Doesn't work from what I've read from people who tried it. Waste of money.....
Old Oct 13, 2007 | 12:36 PM
Freerider's Avatar
Freerider
Now this is controversial. I am inclined to say it doesn't do jack. Just a whole in your wallet. However, the reason we say this is the lack of evidence. People say it helps, and they never post up dyno charts, or anything to support that the chip did... well... exist.
Old Oct 13, 2007 | 01:55 PM
LowSlowNeon
I saw a dyno from someone who had it and it did nothing. No increase...unless he was lying......
Old Oct 13, 2007 | 04:10 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Freerider
There are dyno charts on the other .Orgs that prove it doesnt do anything...
Old Oct 13, 2007 | 04:24 PM
ewetho's Avatar
ewetho
ORIGINAL: 03neonRT
ORIGINAL: Freerider
Seen those dyno charts too. Also someone measured the pins on one side to the matching pins on the other side and ZERO resistance from one side to the other on ALL pins was reported. Unfortunately seems like it has been proven over and over it is JUNK.
