View Poll Results: A poll
Cold Air Intake
45.45%
Lowering kit (not sure which type yet)
54.55%
Voters: 11. You may not vote on this poll
CAI or lowering kit
Old Oct 16, 2007 | 01:33 PM
AirWolf's Avatar
AirWolf
Default RE: CAI or lowering kit
Thanks graph, think Im going to use that imo more so everyone can understand me better .
Old Oct 16, 2007 | 02:01 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: AirWolf
Old Oct 16, 2007 | 02:08 PM
NHARINTON's Avatar
NHARINTON
ORIGINAL: GrApHite03
ORIGINAL: AirWolf
AWWW good to see the fam getting along!!
im with mikey, lower it and pvc a intake, and yes its reliable, thats what ihave and it looks great...... and if you think about it might be better. A metal intake conducts heat alot more then plastic does, you can make it too the same exactshape as a commercial intake!!!
Old Oct 16, 2007 | 02:41 PM
nate_0022's Avatar
nate_0022
I'd say go with a drop and get rid of that nasty wheel gap, but on the other hand CAI intake does hardly anything for hp gains but sounds awesome at WOT. What would your options be as far as spring and shocks, struts?
Old Oct 16, 2007 | 03:09 PM
swimmer07's Avatar
swimmer07
i've been trying to find a tokico kit that puts the car at a 1.5 inch drop, but no such luck as of right now
Old Oct 16, 2007 | 03:13 PM
nate_0022's Avatar
nate_0022
Have you looked into the Eibach pro-kit. Lowers the car about 1.5" all around.. http://eibach.com/cgi-bin/htmlos.exe...1366300028459?
Old Oct 16, 2007 | 03:17 PM
swimmer07's Avatar
swimmer07
i had seen the pro-kit before, but never really looked into it.. if i ended up getting that, would i just be able to buy the pro-kit and not need anything else for instalation? and i didnt see a price on that, what does the price run?
Old Oct 16, 2007 | 03:33 PM
nate_0022's Avatar
nate_0022
Shocks and struts are usually recommended I went with KYB AGX's i'm sure you could run GR-2's. You'll need an alignment after you lower it, also might need a camber kit to sure if you can bring it back to center without one.. I found some springs on ebay for $186. http://cgi.ebay.com/ebaymotors/EIBAC...spagenameZWD1VNot sure if your safe with ebay ones though i'm not positive if their legit or not. If you type in Eibach pro-kit 2820.140 in google you'll be able to find some reputbale souces.
Old Oct 16, 2007 | 03:37 PM
swimmer07's Avatar
swimmer07
ok thanks!! i'll have to research some more.. but the most i'd have to buy would be shocks, struts, and springs?? when i was first looking into this, i thought it was just going to be springs lol
Old Oct 16, 2007 | 03:41 PM
03neonRT's Avatar
03neonRT
The KYB GR2's arent any better then the OEM struts when installing lowering springs. The best struts available to be used in conjunction with lowering springs for a Neon are Tokico HP Blues. The struts will run you $255 shipped and the Eibach Prokit should be around $200. You could always just keep the stock struts and see how long they last for, but theres no guarantee.
And we dont have shocks, only struts...
