Swap to blue guages
Old Oct 23, 2007 | 04:44 PM
  #21
spikeymikey87's Avatar
spikeymikey87
Default RE: Swap to blue guages
put in while bulbs and it will be blue. trust me. you will also still have redline and red where its supposed to be
Old Oct 23, 2007 | 05:25 PM
  #22
jwcorn01's Avatar
jwcorn01
If you put white LEDs in the cluster they will show blue?
Old Oct 23, 2007 | 06:14 PM
  #23
Kalevra's Avatar
Kalevra
yeah, arn't the ones in there now white?
I want mine a nice blue, but I want the needles to be red still and all
Old Oct 24, 2007 | 09:44 AM
  #24
ricerchik02's Avatar
ricerchik02
I think u have to get white leds in order for it to look blue. The white in there now is just a regular bulb so it doesn't look blue. I've heard this works the way spikey said.
Old Oct 24, 2007 | 12:10 PM
  #25
DouglasSXT's Avatar
DouglasSXT
I justfinished doing my gaugesin blue using the wide angle ledbulbs... Also have the dome light and trunk light with led bulbs in blue... I'll post some pics when it gets dark tonight to hopefully show the effect better!
Old Oct 24, 2007 | 12:15 PM
  #26
eaks's Avatar
eaks
Ok i have done both these.. ill upload some pics here...
for the gauge.. what I would recomend is using 5 blue leds and 3 white.. only use the white where the red is.. this gives a better looking blue IMO..
For the HVAC i custom did my own buy gluing in 5mm LEDs.. they are very bright and not the most even glow they could be but the pics make it look worse..
Everything Done..
[img=http://img80.imageshack.us/img80/8418/bl2lz0.th.jpg]
Hvac in 3 parts.. backside with leds off.. back side with leds on.. and then the final installed look..(now i did redo the power and stuff.. this was just for testing with the power supply comming threw the vents..lol
[img=http://img337.imageshack.us/img337/6061/hvac1wa0.th.jpg]
[img=http://img80.imageshack.us/img80/5600/hvac2co7.th.jpg]
[img=http://img131.imageshack.us/img131/4025/hvac5mz9.th.jpg]
Gague.. unfortunantly i have no updated pics after putting the white LEDs in for teh redlines.. but here with all blue LEDs..
[img=http://img221.imageshack.us/img221/6747/gauge5je9.th.jpg]
Old Oct 24, 2007 | 12:23 PM
  #27
Rodge57's Avatar
Rodge57
Bright................ For HVAC
Old Oct 24, 2007 | 12:24 PM
  #28
Rodge57's Avatar
Rodge57
What are the steps you take to get back for the HVAC?
Old Oct 24, 2007 | 02:29 PM
  #29
eaks's Avatar
eaks
To get the HVAC control panal thingy off.. you need to pop out the two vents.. pop in a flat screw drive in a bottom corner and just pop it up and pull it out.. at the top inside of both holes there are two screws to remove.. take thoes out.. then the rest is just pulling it out (there are lots of clips so dont just rip it off)..
PS: you got pm regarding my footwell lighting
Old Oct 24, 2007 | 04:06 PM
  #30
Kalevra's Avatar
Kalevra
IMO the HVACs are too bright.... but i like the guages
so I should use all whites or only whites for the redline and blues for the rest?
