Unidentified neon
Old Oct 28, 2007 | 07:01 PM
MJND1990's Avatar
MJND1990
Default Unidentified neon
i want to remove all my emblems since there peelin. whats the best way to remove the emblems and residue without leavin an outline? mine is a 2000 if that helps.
Old Oct 28, 2007 | 07:06 PM
Freerider's Avatar
Freerider
Default RE: Unidentified neon
fishin line... and bug & tar remover
my vote.
Old Oct 28, 2007 | 11:28 PM
snare_samn's Avatar
snare_samn
Blow drier, WD-40 and a rag.
Old Oct 28, 2007 | 11:33 PM
Izero's Avatar
Izero
dont use WD-40 it doesn't come off and can become corrosive... use a mild polishing compound to get the outlines out and as for the residue... i would use good ole' soap and water and a towel or you can just use the hair dryer to get it pliable and just use your nail(which is what i did, and it came out great).... anyways good luck
Old Oct 30, 2007 | 12:29 AM
underdogneon's Avatar
underdogneon
I have a '00 neon as well, don't take off the door guards and emblems unless you plan on doing a new paint job. The paint around the emblems will be very different from the paint that's been covered. I don't care if you get all that adhesive off, it'll look worse than stock.
Old Oct 30, 2007 | 12:52 AM
Mat00ES's Avatar
Mat00ES
I took off the ES, and just bought some polishing compound to remove the outline. Funny enough I couldn't find it, I've washed the car a couple times and we've had some steady rain since. So, I finally have gained the ***** to remove all the emblems and door guards. I'll try and get some before and after pics.
Mat
Old Oct 30, 2007 | 02:43 AM
Swordfish2Cowboy's Avatar
Swordfish2Cowboy
A hot day (hair drier substitutes well I'm told), a plastic paint scraper, fish line, and Goo Gone.
Old Oct 30, 2007 | 12:13 PM
Mat00ES's Avatar
Mat00ES
well, I pulled back the door guard and the paint is bubbled underneath. So, Im just going to remove the embelms for now.
Mat
Old Oct 30, 2007 | 10:42 PM
DEWDEWZ's Avatar
DEWDEWZ
yeah, i was planning on removing mines also, was gona post some questions about it but since you aready made one il ask here.
my friend said that on his car (not a neon) their were wholes...so my question is, if i take mines off, there wont be any holes rihgt?
Old Oct 30, 2007 | 11:20 PM
12 volt's Avatar
12 volt
isopropyl alcohol can help remove the goo also.
