Tag light is out... Any Suggestions
Old Oct 31, 2007 | 05:51 PM
neonxst05's Avatar
neonxst05
Default Tag light is out... Any Suggestions
Last night I was driving on the highway. I wasnt speeding or anything but a trooper pulled me over. He scared the crap out of me cuz I mean I didnt do anthing. Anyways, it turns out that my tag light is out. So in other words I can get a ticket for having the tag light out. So today I looked at the bulb and it looks fine. I took out my trusty multimeter and tested the line for current and sure ehough there isnt any power. I know that the harness goes into the trunk area on the right side through the floor in the corner below the tailight. The colors are black and blask with two yellow stripes. I noticed that the striped wire goes to the tailight. Well My car is only 2 years old and no electrical work has been ever done. I do have an audio system too. Any guggestions are appreciated, as to up to this point I dono what to do since I checked all my fusses too.
Thanks a bunch.
Old Oct 31, 2007 | 06:03 PM
GrApHite03's Avatar
GrApHite03
Default RE: Tag light is out... Any Suggestions
did you trya new bulb?
Old Oct 31, 2007 | 06:13 PM
Pharmboy's Avatar
Pharmboy
Do both tail lights work fine? I'll assume so- start by checking the black wire for ground (while lights are on or off). The only other possibility is that the black W/ yellow wire has come loose at it's splice in the loom because the tail lights for the right side are actually after the license splice. (First just try changing the bulb 98% possibility it's the bulb, 1% it's the ground [spliced into tail light ground], and 1% it's the power [also spliced from tail light loom]
Old Oct 31, 2007 | 06:18 PM
Pharmboy's Avatar
Pharmboy
These may help you understand what I'm trying to say.
Old Oct 31, 2007 | 08:13 PM
neonxst05's Avatar
neonxst05
Yea I tried a new bulb. I guess I have to dig around a little more in the wires and take a closer look. Sonce I am just a university student I live in a dorm so its gona be fun tearin it all apart in the lot. Lol. Thanks for the diagram. Now I know how its all run.
Old Oct 31, 2007 | 08:28 PM
Pharmboy's Avatar
Pharmboy
yeah I understand your situation, your next step though is to test continuity or the resistance between the black at the plate light and the black at the tail light and the same for the black and yellow. The open one will be the one you need to chase. Let me know what you find.
Old Nov 1, 2007 | 01:38 PM
neonxst05's Avatar
neonxst05
I will. I have classes and as soon as I get freed up I will geton it.
I will post the results as soon as I can.
Old Nov 2, 2007 | 02:10 PM
03neonRT's Avatar
03neonRT
Did you check your fuses?
Old Nov 2, 2007 | 10:16 PM
Pharmboy's Avatar
Pharmboy
his fuses are fine, if they were the problem, he would have no tail lights.
Old Nov 4, 2007 | 12:18 AM
neonxst05's Avatar
neonxst05
Well I tried my best to fix the light but I realy did not have the time and the resources to go all the way in the electrical. So i just went and bought an white LED light bar designed for the tag. I tapped tapped into the the parking light wires on the tail light. I ran new wire for the light that came with the light bar. So I still dont know how to fix the main problem but hey i got a brighter light now.
