Few problems
Old Nov 8, 2007 | 10:35 AM
hut's Avatar
hut
Default Few problems
The first issue is that only one of my low beams is out but the high beam still works, tried replacing the bulb and nothing same problem. Could this be a wiring issue?
Next is when I hit about 45mph it starts to vibrate and it also vibrates when I’m stopped at a light. I replaced a cracked air hose and still nothing.
Shawn
Old Nov 8, 2007 | 01:54 PM
Pharmboy's Avatar
Pharmboy
Default RE: Few problems
fuses are in the driver side doorway that's your light problem
Old Nov 8, 2007 | 02:49 PM
neonxst05's Avatar
neonxst05
As fo r the vibration, make sure your tires are balanced, rotors are in good shape, not warped, and check the brake pads as well. Also time pressure check would be good.
Old Nov 8, 2007 | 03:28 PM
Pharmboy's Avatar
Pharmboy
yeah and try a tune up for the idle vibation
Old Nov 8, 2007 | 03:38 PM
Adionik's Avatar
Adionik
Check motor mounts and note that neons are known to vibrate. The steering column, dash and Hvac (Although varying by car) have been known to rattle
Old Nov 8, 2007 | 11:37 PM
hut's Avatar
hut
Alright thanks guys I'll get to it and let you know how things went.
