SRT4 Suspension in a stocker Neon
Old Nov 8, 2007 | 09:16 PM
MadScotsMan's Avatar
MadScotsMan
Default SRT4 Suspension in a stocker Neon
Is the suspension (struts, springs, sway-bars) from an SRT4 interchangable on a 2000 Neon? Are there any problems with this swap?
Thanks.
MSM[sm=alcoholic.gif]
Old Nov 8, 2007 | 09:51 PM
ewetho's Avatar
ewetho
Default RE: SRT4 Suspension in a stocker Neon
Ride height may raise a touch up front for the clearance allowed for the large SRT4 tire and wheel package. But the parts are interchangable on all 2gn cars. You have to watch ride height when mixing SRT and Non-SRT struts and springs.
The SRT front control arms are also heavier duty to deal with the stress of the motor.
If you get into the knuckles steering geometry changes as well as the brakes. So if you swap to SRT stuff plan on switching to an SRT rack-n-pinion or altering the stock stuff.
Old Nov 9, 2007 | 12:28 PM
03neonRT's Avatar
03neonRT
ORIGINAL: ewetho
+1.
Old Nov 10, 2007 | 12:08 AM
Yako's Avatar
Yako
talking about srt suspension, so right now i got stock neon struts and springs, with 17s on, 205/40 tires,
so if i get the srt struts and springs can i go with bigger tires liek 205/50s???
Old Nov 10, 2007 | 12:29 AM
Adionik's Avatar
Adionik
I have stock SRT struts with SRT springs, rear and front stock SRT sway bars on 17' SRT rims...
I picked up my front and rear sway bars for $20. That's $10 a bar! HAHA. Struts only cost me $60 and rims with tires were $200.
Installed everything myself, and if my dumbass can do it I think anyone can. QFT!
Old Nov 10, 2007 | 09:13 PM
contagious19's Avatar
contagious19
ORIGINAL: Adionik
....Installed everything myself, and if my dumbass can do it I think anyone can. QFT!
[sm=icon_rofl.gif]dats da same way i feel. if i can do it anyone can.
Old Nov 12, 2007 | 10:40 PM
MadScotsMan
So, I cannot use the SRT springs and struts without modifying or swapping out the front rack? Should I be looking for ACR springs instead?
Thanks.
Old Nov 12, 2007 | 11:16 PM
NHARINTON's Avatar
NHARINTON
no, you dont have to mod the rack, thats only if you do a srt motor swap, your good to go, will swap straight our, lifts the frunt 1/2' i belive
Old Nov 13, 2007 | 09:01 PM
03neonRT's Avatar
03neonRT
ORIGINAL: NHARINTON
Yeah you only need to change the steering rack if you swap the motor, or install un-modded SRT-4 knuckles for big brakes or SRT-4 brakes.
