UDP worth it?
Old Nov 9, 2007 | 05:45 PM
  #21
NeonPerformance88's Avatar
NeonPerformance88
Default RE: UDP worth it?
ORIGINAL: Pharmboy
ORIGINAL: neon03se
i'd rather have a bunch of girls around my car because it is nice than a bunch of guys cuz its fast.
awesome never thought of it that way before
hahaha indeed!
Old Nov 9, 2007 | 06:06 PM
  #22
lblackneon's Avatar
lblackneon
I have several mods on my Neon ES. I took off my AFX Udp and didn't feel a difference in power. There is a power increase with the aftermarket udp but it's no big deal. It seems as if it broke things on my car.
Old Nov 9, 2007 | 06:48 PM
  #23
neon03se's Avatar
neon03se
thats exactly what i dont want lol
Old Nov 9, 2007 | 06:55 PM
  #24
lblackneon's Avatar
lblackneon
Some people claim they don't have problems with them but I wouldn't mess with it.
Old Nov 9, 2007 | 09:22 PM
  #25
Adionik's Avatar
Adionik
ORIGINAL: 03neonRT
Poor electrical system grounds are what your experiencing...most Neons have that same problem, and its easilly fixed with a grounding kit (either DIY or preassembled).
My 4ag ground replacements didn't fix that, I think its just a neon thing jared
Old Nov 9, 2007 | 10:35 PM
  #26
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
ORIGINAL: 03neonRT
Then you suck at making grounding kits Anthony , and yes, it is a Neon think either way lol.
Old Nov 9, 2007 | 11:16 PM
  #27
Adionik's Avatar
Adionik
I still kinda want one.[:@]
Old Nov 10, 2007 | 01:48 AM
  #28
Swordfish2Cowboy's Avatar
Swordfish2Cowboy
ORIGINAL: Kalevra
id the UDP smaller than the stock one? if so it would be spining the belt alot less therefore everything that gets power from the belt it's efficiently will be cut dramatically weather or not the other pulleys are changed, simple pully theory or should I say rotational thorty... the bigger the wheel or pully, the more distance it will travel with one rotation, the smaller the less the distance. say the pully is 10 inches around, that means for every rev the belt moves 10 inches, and same with an 8 inches, it will move 8 inches/ revolution therefor reducing efficiency, turning the belt less and there for turning the other pulleys less
So, in conclusion, IF the pully is smaller than stock then it will reduce the efficentcy of all the accessories on that belt. that means, AC, alt, pwr stearing, everything due to the belt spinning slower because of a smaller UDP
EDIT: wow, I think I just outsmarted 03RT
I'm sorry any argument you may have had went out the window when I saw your atrocious spelling.
Old Nov 10, 2007 | 12:50 PM
  #29
Kalevra's Avatar
Kalevra
ORIGINAL: Swordfish2Cowboy
ORIGINAL: Kalevra
if (typo) the UDP smaller than the stock one? if so it would be spinning (typo) the belt a lot less therefore everything that gets power from the belt it's efficiently will be cut dramatically weather or not the other pulleys are changed, simple pulley theory or should I say rotational theory(typo, sorry)... the bigger the wheel or pulley, the more distance it will travel with one rotation, the smaller the less the distance. say the pully is 10 inches around, that means for every rev the belt moves 10 inches, and same with an 8 inches, it will move 8 inches/ revolution therefor reducing efficiency, turning the belt less and there for turning the other pulleys less
So, in conclusion, IF the pulley is smaller than stock then it will reduce the efficiency (another typo) of all the accessories on that belt. that means, AC, alt, pwr steering (donno what I was thinking there), everything due to the belt spinning slower because of a smaller UDP
the bold words without a caption I admit I didn't know I was misspelling. sorry. the captions will tell it all and why it was misspelled. though, the minor misspellings should not have effected the point I was making, I'm not Mr. perfect, or always right, but you're going to discredit my point just because of some spelling errors that didn't take away from the readability of the statement above? I hate those who are always grammatically correct and discredit everyone who is not. that's just like being racist, you racist bastard
Old Nov 14, 2007 | 06:16 PM
  #30
Adionik's Avatar
Adionik
So don't get one?
