Turbo
Old Nov 10, 2007 | 10:59 PM
tonxcab's Avatar
tonxcab
New Member
Default Turbo
Can I put a 2000-02 Hahn Race Craft
Stage2tutbo kit a stock motor in aauto transneon when I'm done rebuilding the motor will it handle it.
Old Nov 10, 2007 | 11:39 PM
Adionik's Avatar
Adionik
Default RE: Turbo
Yes...you can. Then later down the line, you might wanna pick up a tranny rebuild kit.
Old Nov 10, 2007 | 11:46 PM
tonxcab's Avatar
tonxcab
New Member
Default RE: Turbo
Cool that is what I wanted to hear I didn't know if the stock motor would handle it but I think it will be a blast to drive
Old Nov 11, 2007 | 12:00 AM
GrApHite03's Avatar
GrApHite03
Default RE: Turbo
The motor will handle it, but the auto tranny may not for long. And yes, it is quite a blast... i made 219 wheel hp and 244 wheel tq with a custom kit.
Old Nov 11, 2007 | 12:16 AM
AirWolf's Avatar
AirWolf
Default RE: Turbo
You need to have your tranny built up like my 1st gen it has a hahn stage 2 kit also . Then you should be ok.
Old Nov 11, 2007 | 12:26 AM
tonxcab's Avatar
tonxcab
New Member
Default RE: Turbo
Who has a good tranny kit and some prices
Old Nov 11, 2007 | 12:47 AM
tonxcab's Avatar
tonxcab
New Member
Default RE: Turbo
Are these good
High Performance Overhaul Kit for the Neon A670 Automatic Transaxle. Designed for high performance street and strip use, this kit starts with a top quality seal and gasket set. From there a Red Eagle brand intermediate band takes care of tire chirping 1-2 shifts. The forward and high gear friction plates are also a race proven Red Eagle lining with a special double saturation process that virtually eliminates burning warping. To combat a weak high gear clutch pack extra plates are added to the kit to increase clutch capacity for full power shifts. Kolene steel clutches are included that have a superior surface treatment that reduces wear and fatigue from 200% - 500%. New bushings, washers and a filter finish this kit. $249.99
Street/Strip valve bodies that fits Chryslers Neon with A670 Transmissions. The Street/Strip is fully automatic and produces tire chirping shifts. Filter, gasket and instructions are included and installs in less than two hours with simple hand tools. Get the performance you need! Unit only works with the three speed transmissions from 95-2001 $239.99
Old Nov 11, 2007 | 01:01 AM
Adionik's Avatar
Adionik
Default RE: Turbo
If you're sure you have a 3-speed atx, i'd get the valve body. Otherwise, another guy on 2gn turbo'd his atx and used that rebuild kit....no complaints from him.
Old Nov 11, 2007 | 02:23 AM
leadspud's Avatar
leadspud
Default RE: Turbo
I've been running a turbo on my automatic 2000 neon for about six plus months. No problems yet
Old Nov 11, 2007 | 02:59 AM
GrApHite03's Avatar
GrApHite03
Default RE: Turbo
ORIGINAL: leadspud
what's your set-up/power/boost levels... If you over 200whp you must drive like my grandma. I've seen tons of un-modded ATXs crap out once you cross or get close to the 200 range.
k3v
