Official 2nd gen offtopic thread...
Old 11-28-2007, 03:32 PM
Mat00ES's Avatar
Mat00ES
Mat00ES is offline
Default RE: Official 2nd gen offtopic thread...
My other hobby:
http://i20.photobucket.com/albums/b2...Picture003.jpg
http://i20.photobucket.com/albums/b2...5/DSCN0019.jpg
Mat
EDIT: Im too much of a noob to post them, so you get links.
  #52
Old 11-28-2007, 04:13 PM
neon03se's Avatar
neon03se
neon03se is offline
so it's still 10am over there! It's 2 here, I wish it was mornin so i could be sleepin right now!!!
my car would probably be drowning if i were in hawaii lmao
  #53
Old 11-28-2007, 05:25 PM
GrApHite03's Avatar
GrApHite03
GrApHite03 is offline
My 2ng Neon Modification Instruction Manual
13.1 AUTHORIZED MODIFICATIONS
If a modification is not specifically authorized in this or previous sections of these Rules it is not allowed. It is not permitted to use illegal parts even if they have been set to stock specifications.
Refer to Appendix F for past clarifications of these rules.
13.2 BODYWORK
A. Accessories, gauges, indicators, lights and other appearance, comfort and convenience modifications which have no effect on performance and/or handling and do not materially reduce the
weight of the car are permitted. This does not allow driver’s seat substitutions, or the removal of “tow hooksâ€, a.k.a. “tie-down loopsâ€. Delayed shutdown devices such as the “Turbo Timerâ€,
which perform no function while the car is in motion, are permitted. This does permit the installation of an additional mirror (e.g. a “Winkâ€), but does not allow the removal of the original mirror.
“Grounding kits†specifically designed to support sound systems are permitted but may serve no other purpose.
B. Hood straps or fasteners may be added.
C. Any fuel tank cap may be used.
D. Windshields may be folded (but not removed) provided the required mechanism is standard equipment.
E. Alternate steering wheels are allowed, provided the outside diameter is not changed by more than one inch from the standard size. Steering wheels with an integral airbag may not be changed.
F. Spare tires, tools and jacks may be removed. Any fastening hardware and/or other pieces that can no longer be firmly secured in the absence of the spare tire may be removed if necessary to
ensure compliance with 3.3.3.B.1.
G. Roll bars and roll cages may be added (See Appendix C). It is strongly recommended that roll cages be constructed according to Section 18 of the GCR, though they must be bolted (not welded)
into the automobile and be contained within the driver/passenger compartment. Roll bars may be welded in. A roll cage has more than four attachment points to the body or frame, or has bracing
both fore and aft of the main hoop.
H. Driver restraints as outlined in Section 3.3.1 are allowed. Seats may not be cut to allow for the installation of alternate seat belts or harnesses. Passive restraint systems may not be removed. A
horizontal “harness bar†may be used as part of the installation hardware for allowed driver restraints. It may serve no other purpose (e.g., structural enhancement).
I. Cars may add one rear trailer hitch. The resulting weight addition is allowed. The hitch may serve no other purpose. Factory tie downs may be removed to facilitate hitch installation.
J. Tow bar brackets may be installed but may serve no other purpose.
K. Any item that cannot be held permanently in place by factory installed fasteners may be removed.
13.3 TIRES
Any tire which is OE on a car eligible for Stock Category may be used. Non-OE tires must meet the following requirements to be eligible for use in Stock category:
A. The tire must not appear on the following list, which may be altered at any time by the SEB upon notification of membership. No tire models are currently listed.
B. No tire models will be approved for competition during the rest of the year after April 30 of each calendar year. Each eligible tire model must meet all requirements of Section 13.3 by April 30, and must continue to meet them thereafter. A tire model will normally be determined by the designation in the Tire Guide. However, any of the following changes or similar changes (as determined by the SEB) will also be considered to represent a new model for eligibility purposes, even if the designation does not change: change of tread pattern at either full or partial tread depth; characterization by the manufacturer or distributor of a tire as “new†after April 30. A tire model which was previously allowed by these rules continues to be legal until specifically disallowed. This follows years of precedence on eligibility for discontinued tire models. If a manufacturer reintroduces a tire model which was previously discontinued, that tire will be considered a new model. Therefore, it will have to meet the rules specified in SR Section 13.3 including the April 30 introduction date.
C. The model of tire must be listed in a current or previous two years of the Tire Guide and Tread Design Guide, or otherwise be approved by the SEB. The tire model must have Department of Transportation approval.
D. Within each tire model, the sizes which are available must be equally available to all competitors. Tire model variations differing from standard specification, delivered only on a limited basis, or only to selected competitors, may not be used.
E. No racing tire or recap (on any casing) may be used.
F. Each tire model must be sold in at least four rim diameters, with a total of at least six sizes.
G. Tire must fit the allowable wheels and fender wells without modification.
H. Each tire must have non-zero measurable tread depth (i.e., points where it is possible to obtain positive measurement values) as described in Section 3.3.D. Tires may not have cord visible at any time during competition.
13.4 WHEELS
Any type wheel may be used provided it complies with the following:
it is the same width and diameter as standard, and as installed (including wheel spacers if applicable) it does not have an offset more than +/- 0.25 inch from a standard wheel for the car. The resultant change in track dimensions is allowed. Wheel spacers are permitted, provided the resultant combination complies with the offset requirements of this section. Wheel studs, lug nuts, and/or bolt length may be changed.
Vehicles equipped with rims having metric specifications may use alternate rims as determined by using the following procedure:
Diameter: converting the metric measurement to inches and using the nearest smaller inch diameter rim.
Width: converting the metric measurement to inches and using the nearest smaller 1/2-inch width rim. Offset and track must still comply with the requirements of this section.
13.5 SHOCK ABSORBERS
A. The make of shock absorbers may be substituted providing that the number, type (e.g., tube, lever, etc.), system of attachment and attachment points are not altered, except as noted below.
The interchange of gas and hydraulic shocks absorbers is permitted. The following restrictions apply:
1. No more than two separate external shock damping adjustment controls. This permits the use of shocks which originally came with more than two external adjustments, which have been converted to double-adjustables, only if the additional adjustment controls have been permanently disabled (e.g. via welding, epoxying, grinding off). Gas pressure adjustment is not considered a damping adjustment.
2. Suspension geometry and alignment capability, not including ride height, may not be altered by the substitution of alternate shock absorbers.
3. Adjustable spring perches are allowed, but the spring load bearing surface must be in the same location relative to the shock mounting points as on the standard part. Shims may be used to achieve compliance.
4. The fully extended length must be within plus or minus one inch of the dimension of the standard part.
5. Electronically controlled shocks may not be used on vehicles not originally equipped with such units. Vehicles originally equipped with electronically controlled shocks may use the standard parts or non-electronically controlled alternative shocks subject to all the requirements of 13.5. Non-standard electronically controlled shocks are not allowed.
B. The mounting hardware shall be of the original type. The use of any shock absorber bushing material, including metal, is permitted. Pressed or bonded bushings may be removed from standard
parts to facilitate the use of alternate bushings which fit in the original location without alterations to the part. This does not permit the use of an offset shock bushing. A shock absorber bushing may be implemented as a spherical bearing. The bushing attaching the end of a strut to the body or frame on a strut type suspension is a suspension bushing, not a shock bushing.
C. To facilitate the installation of commonly available aftermarket shock absorbers, struts, or strut inserts whose shaft size is larger than the center hole of an upper shock mount assembly, that hole may be enlarged by the minimum necessary to accommodate the shock shaft size, provided the following restrictions are met:
(1) the enlarged hole must remain concentric with the original configuration;
(2) the enlargement of the hole does not require modification of a bearing (as opposed to a washer, sleeve, or plate);
(3) neither the hole enlargement nor the location of the shock shaft changes any alignment parameter. Provided these constraints are met, this permits enlarging of the center hole in an upper shock mount with an integrated rubber bushing, where the bushing is integral to the mount and bonded to the plate and the mount is provided by the OEM as an assembly. This includes drilling out and/or removal of the metal sleeve.
A bonded shock bushing/plate assembly is considered a shock mount assembly and not a bushing. It may not be replaced with an aftermarket performance part. It is not permissible to replace the bonded bushing material.
D. A suspension bump stop is considered to be performing the function of a spring. Therefore, the compressed length of the shock at the initial point of contact with the bump stop may not be increased from the standard part, although the bump stop may be shortened for the purpose of installing non-standard shocks. Bump stops installed externally and concentric with the shaft of a shock may be drilled out to fit a larger diameter shock shaft. Bump stops may be substituted for the purposes of installing non-standard shocks.
E. A hole may be added through the bodywork to route the line from the reservoir to the shock absorber body. Such holes may serve no other purpose.
F. A hole may be added to an interior body panel to provide access to the adjustment mechanism on an allowed adjustable shock absorber. The hole may serve no other purpose, and may not be added through either the exterior bodywork or a strut bar. Interior panels are defined to be those pieces which cover the interior of the vehicle and are accessible from inside the vehicle. They do not include structural panels, such as wheel wells or inner fenders, which may also be accessible from inside the car but which actually form part of the body of the vehicle.
13.6 BRAKES
A. The make and material of brake linings may be changed.
B. Substitution of clutch and brake hydraulic lines with solid metal or braided metal is allowed on all cars manufactured before model year 1992.
C. Alternate brake bleeder fittings such as “Speedbleeders†are permitted. They may serve no other purpose.
13.7 ANTI-ROLL (SWAY) BARS
A. For front anti-roll (sway) bars:
1. Substitution, addition or removal of any front anti-roll bars is permitted.
2. Substitution, addition or removal of anti-roll bars may serve no other purpose than that of an anti-roll bar.
3. The use of any bushing material is permitted.
4. No modification to the body, frame or other components to accommodate anti-roll bar addition or substitution is allowed, except for the drilling of holes for mounting bolts. Non-standard lateral members which connect between the brackets for the bar are not permitted.
B. Rear anti-roll (sway) bars may not be removed, replaced, or modified in any way.
13.8 SUSPENSION
A. Standard, as defined herein, suspension springs must be used. They may not be cut, shortened or collapsed. Cars with swing axle suspension may be lowered sufficiently to achieve no more than two degrees of negative camber at rest, and may use a camber compensator. Spring perches may not vary from the OE shape within the working part of the perch.
B. Both the front and rear suspension may be adjusted through their designed range of adjustment by use of factory adjustment arrangements or by taking advantage of inherent manufacturing tolerances. This encompasses both alignment and ride height parameters, if such adjustments are provided by the stock components and specified by the factory as normal methods of adjustment. However, no suspension part may be modified for the purpose of adjustment unless such modification is specifically authorized by the factory shop manual for non-competition purposes.
C. Suspension bushings, including but not limited to those which carry the weight of the vehicle and determine ride height, may not be replaced with bushings of a different material or dimension.
D. Replacement control arms for vehicles having integral bushing/arm assemblies must be standard factory parts as per Sections 12.4 and 13.0.
E. If authorized by the manufacturer, the use of shims, special bolts, removal of material to enlarge mounting holes, and similar methods are allowed and the resulting alignment settings are permitted even if outside the normal specification or range of specifications recommended by the manufacturer. If enlarging mounting holes is specifically authorized but no material removal limits are specified, material removal is restricted to the amount necessary to achieve the maximum factory alignment specification.
13.9 ELECTRICAL SYSTEM
A. The make of spark plugs, points, ignition coil and high tension wires is unrestricted including spark plug wires having an in-line capacitor.
B. On cars made prior to January 1, 1968, any ignition system using a standard distributor without modification may be used.
C. Ignition settings may not be adjusted outside factory specifications.
D. No changes are permitted to electronic engine management systems or their programming.
13.10 ENGINE AND DRIVE TRAIN
A. The engine air filter element may be removed or replaced. A replacement element which is taller than standard may not be used to hold the air cleaner cover open. No other components of the air induction system may be removed, replaced or modified.
B. Engines may be rebored to the manufacturer’s first standard overbore, not to exceed 0.020". Sleeving is allowed to repair to the standard bore. Only OE-type standard or first overbore pistons of the same configuration and of the same or greater weights are permitted. No interchange between cast and forged pistons is allowed.
C. Rotating and reciprocating parts may not be balanced.
D. Port matching is not allowed.
E. Any part of the exhaust system beyond (downstream from) the header/manifold or catalytic converter, if so equipped, may be substituted provided the system meets the requirements of 3.5. Stainless steel heat exchangers are permitted only if the physical dimensions and configuration remain unchanged. Modifications of any type, including additions to or removal of, the catalytic converters, thermal reactors, or any other pollution control devices in the exhaust system are not allowed and the system must be operable. Replacement catalytic converters must be OE if the vehicle has not exceeded the five-year/50,000 mile warranty period as mandated by the EPA. Converters must be of the same type and size and used in the same location as the original equipment converter(s). This does not allow for a high performance unit. If the vehicle has exceeded the five-year/50,000 mile warranty period, replacement catalytic converters must be OE-type as per Section 13. Exhaust hangers which are bolted or welded on the car are considered part of the body and may not be changed or removed.
F. Any oil filter may be added if not originally equipped. Canister type oil filters may be replaced with a spin-on type filter using a minimum amount of hardware and connecting lines.
G. The installation of water expansion tanks is allowed. The installation of oil catch tanks is allowed provided the PCV system is not altered.
H. A scatter shield may be added. This does not permit bell housing substitutions.
I. Thermostats may be added or substituted. A thermostat is a device which controls the passage of water.
J. Silicone replacement hoses are permitted as alternate components, provided they meet the requirements of Section 13.0 with regard to size, shape, location, and performance equivalence. Replacement induction system air intake hoses must also match the standard part in stiffness, contour, and internal wall texture.
K. A device for locking out reverse gear may be used.
L. Limited-slip differential, transmission and differential ratios, clutch mechanisms and carburetion, fuel injection or supercharger induction systems must be standard as herein defined.
M. Any oil or grease, including synthetic, is permitted.
N. Valve seats and guides in older engines originally designed for leaded fuel may be only substituted with alternate components if the dimensions are the same as those of the standard components.
O. Electronic traction and/or stability control systems may be turned off or disabled, as long as this does not require connection to an external system, removal of any part, or the substitution or modification of any part.
  #54
Old 11-28-2007, 06:00 PM
LowSlowNeon's Avatar
LowSlowNeon
LowSlowNeon is offline
http://www.bungie.net/Stats/Halo3/De...yer=R3LeNTLe55
Add me if you want. I play just about every night for awhile.
  #55
contagious19's Avatar
contagious19
contagious19 is offline
ORIGINAL: Adionik
Oh i love seeing how all the excuses go flying!!!!!!
Graphite, what's your gamertag?
I'll add Chris and Chris when i get home haha
funny how our first 5 letters are da same. but well c wat happens
  #56
Old 11-28-2007, 07:54 PM
Adionik's Avatar
Adionik
Adionik is offline
I'm on live!!!!!!!!!!!!!
I'm trying to add all your names right now.
  #57
Old 11-28-2007, 09:18 PM
Andpto's Avatar
Andpto
Andpto is offline
so what do u guys want for christmas? or whatever holiday u do?
i want a nikon d40
  #58
Old 11-28-2007, 11:44 PM
Undesolved's Avatar
Undesolved
Undesolved is offline
graphite what is that BIG ol list you just posted?
  #59
Old 11-29-2007, 12:14 AM
GrApHite03's Avatar
GrApHite03
SCCA Stock Class rules for SoloII
  #60
Old 11-29-2007, 12:24 AM
Adionik's Avatar
Adionik
Adionik is offline
graphite get on live
Quick Reply: Official 2nd gen offtopic thread...
