auto start
Old Dec 12, 2007 | 05:25 PM
ramit2001's Avatar
ramit2001
Default auto start
I just installed a bulldog autostart into my fiance "03 Neon and was trying to find an easy way to hook-up the door locks. My question is, has anyone done this and/or does anyone have any tips on where it is the easiest to access the wires for the door locks. I have everything else done and ran out of energy to tackle that one last project so am still using the factory key fob for the locks. Any help would be greatly appreciated.[sm=smiley21.gif]
Old Dec 13, 2007 | 04:44 PM
ramit2001's Avatar
ramit2001
Default RE: auto start
What, no one knows the easiest place to access the door lock wires or has a good detailed wire diagram, or is this here area just for how to make you car faster. I have posted a couple of threads in this area and have got nothing not even a hi or look here. I have gotten alot of help from the 2nd gen ram area. Maybe there is too many young kids in here just looking out for themselves. Just my opinion.
Old Dec 13, 2007 | 05:56 PM
Mat00ES's Avatar
Mat00ES
wow, Maybe no one knows..
Anyway, I have auto start in my car, its only is set up to start the car, doesn't lock or unlock the car.Its one of the ghetto rigged things, I even have to have a chipped key next to the ignition for it to work.
Mat
Old Dec 13, 2007 | 07:49 PM
Pharmboy's Avatar
Pharmboy
If you need our help to find out what wires do what, you won't be able to wire it in correctly anyways. not trying to sound mean, but if you just force the actuaters it'll set bcm codes, the correct way is to trick the rke module.
Old Dec 13, 2007 | 11:08 PM
Undesolved's Avatar
Undesolved
Off but on topic Q: Why can you only put an autostart thing on automatics? cause i get bored and go to like the dodge website and build random cars and it won't let me do autostart with MTXs.
WHY!
Old Dec 13, 2007 | 11:46 PM
Pharmboy's Avatar
Pharmboy
safety, if a relay or sensor goes bad there's a possability that it can start in gear, and they don't want that liability.
Old Dec 14, 2007 | 07:46 PM
Undesolved's Avatar
Undesolved
ah that would make sense...
Old Dec 14, 2007 | 08:39 PM
NeonDon's Avatar
NeonDon
Found this "How to" on bypassing the clutch for remote starting. Haven't tried it nor do I know if the wiring configuration is the same. Try at your own risk.
http://www.srtforums.com/forums/f75/...-start-328883/
