NeonOn19s Project thread
Old Jan 20, 2009 | 03:03 PM
  #291
NeonOn19s's Avatar
NeonOn19s
yeah.. it should be fun... LOL
Old Jan 20, 2009 | 03:33 PM
  #292
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
the disasembly is the most fun, then bolting the turbo up is even better!!!!! good luck and keep up the good work. would u happen to have a pic of what u had to do to the fuel rail when u modified it to fit the 2.0?? if so i really would like to see. i want to make sure i can get it to work with the indy manifold i am using, thanks nate
Old Jan 20, 2009 | 03:41 PM
  #293
NeonOn19s's Avatar
NeonOn19s
Dave.
All that I actually did was use a dremel and open the mounting hole off the fuel rail to make it fit.
That is all I really did.
Old Jan 20, 2009 | 08:09 PM
  #294
dtjackten's Avatar
dtjackten
sweet that is it??? if so i think i am going to get one for my car, prolly in the silver though... money is tight so unfortunatly the block is not going to get done and i miss driving the car so much i am going to run the car at low boost again... it sucks but i will have everything done next winter... it sucks
Old Jan 20, 2009 | 08:35 PM
  #295
srtgtr34's Avatar
srtgtr34
Nice work!, Looks like you need some tires soon...
Old Jan 20, 2009 | 09:49 PM
  #296
NeonOn19s's Avatar
NeonOn19s
Naw not yet.. LOL I just need to get it aligned thats all. still alot of tread left.
Old Jan 21, 2009 | 01:39 PM
  #297
mat663's Avatar
mat663
yeah, that was the same thing I was thinking when I saw the outer edge of his tires all worn out.
Do your doors and hood touch each other when they are opened all the way? It looks like they are touching.
Old Jan 21, 2009 | 04:59 PM
  #298
NeonOn19s's Avatar
NeonOn19s
nope there is about a 1/4 in of clearence.. even with the wind blowing they don't touch. the doors are real sturdy.
Old Jan 23, 2009 | 02:25 PM
  #299
dtjackten's Avatar
dtjackten
nate does the feed line nipple of that fuel rail unthread????
Old Jan 23, 2009 | 02:32 PM
  #300
NeonOn19s's Avatar
NeonOn19s
Yes it does. This fuel rail gives you the option to change the nipple to where it works for you, or upgrade it to a AN fitting .
