Nitruos on R/T it is good ?
I Just installed NOS system on my 2001 R/T 75 shot
I dont know if I need Injectors, fuel rail and fuel pump
and if I need a cam gear for time retard?
I had Comp cam 400-8
Injen cold air intake
kirk header long tube
Magnecor wires
NGK Iridium spark plugs
Unorthodox crank pulley
Magnecor wires
RE: Nitruos on R/T it is good ?
If you installed a wet kit then it should have nozzles for fuel. You need to find the right size fuel nozzle for the shot size you are using. A dry kit you would have to provide your own some how. I do not suggest anyone using a dry kit.
Nitrous is no different than a turbo or supercharger. You are just adding more oxygen/air to the the combustion chamber. As with a turbo or SC you will need to add fuel to compensate and keep a safe air fuel ratio.
Trending Topics
a 75 shot is alot if u ask me.... but if u have the comp 400-8 cam , the crank pully as well as some other stuff i dont see a problem with it.... just a quick question.... how much is the N2O? like how much to fill the bottle up...?
i forgot to ask.... is this a direct port wet kit or is it a single port ?
