Popping from underneath!
Old Dec 1, 2004 | 08:38 PM
Neonsxt0486's Avatar
Neonsxt0486
Default Popping from underneath!
Whenever I take a turn in my car hard I get a popping sound coming from underneath. It's kinda unnerving. It kinda shakes the car. It only comes from the back. It sounds like on the passenger side. What could this be? I know it's still under warranty and I could take it in but theyll just tell me nothings wrong with it. Should I just tighten things up down there ? It's an 04 sxt 5 speed with 5,824 miles. Thanx
Old Dec 1, 2004 | 09:01 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Popping from underneath!
Better description would be nice....what are you going to tighten if you have no idea what the problem is? Does it sound like your exhaust popping, suspension making a noise....etc More info needed.
Old Dec 1, 2004 | 09:07 PM
Neonsxt0486
Deffinately suspension. I Checked the exhaust and everything was fine except theres small hole in my brand new r/t muffler that the dealership just replaced. Its the rear passenger side suspenison popping when i turn.
Old Dec 1, 2004 | 10:48 PM
LowSlowNeon
Have you done any suspension work such as lowering springs? I personally would take it to the dealer if I hadn't done anything to the suspension, let them figure it out.
Old Dec 1, 2004 | 10:50 PM
LowSlowNeon
ORIGINAL: Neonsxt0486
And if I'm not mistaken the hole in your muffler is supposed to be there. I couldn't honestly tell you why, but there is one on my stock muffler. My friend probably told me why it was there but I forgot.
Old Dec 1, 2004 | 11:08 PM
Neonsxt0486
Nope I havent done any suspension work at all. It's bone stock suspension wise. Not for long though Yea i'll probably wind up taking it to the dealer tomorow then. Thanx
Old Dec 1, 2004 | 11:43 PM
mopar32's Avatar
mopar32
I had a similar problem with my Neon. I took it in to get it checked out and it was a broken bolt on the swaybar. The guy fixed it and no more noise.
Old Dec 2, 2004 | 03:53 AM
casper's Avatar
casper
Yep, goto the dealer and have them fix it, if its under warenty.
Old Dec 2, 2004 | 02:55 PM
GroundControl's Avatar
GroundControl
where is that bolt located cuz i lowerd mine but it only makes noise in the back right when i hit a hard bump . other wize it never makes noise.
Old Dec 2, 2004 | 10:44 PM
casper's Avatar
casper
Ground control, how did you lower it? It could be hitting the limits and bottoming out.
