crome valve cover for 2.0???
Old Jan 2, 2008 | 05:13 PM
NHARINTON's Avatar
NHARINTON
Default RE: crome valve cover for 2.0???
here is one for a 1st gen... e-mail them.... ya never know
http://cgi.ebay.com/ebaymotors/POWDE...QQcmdZViewItem
[/align]
Old Jan 2, 2008 | 11:48 PM
Andpto's Avatar
Andpto
Get an R/T valve cover. Its metal not plastic like ours then you can get it dipped
Old Jan 3, 2008 | 02:28 AM
Izero's Avatar
Izero
i thought that the stock es/se/sxt valve covers were plastic coated not completely plastic.....
Old Jan 3, 2008 | 02:39 AM
ironeagle_1983's Avatar
ironeagle_1983
I I found a valve cover for the 2.0 its carbon fiber from dodge but they want 500 dollars for it
Old Jan 3, 2008 | 09:47 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
HMMM...... the first gen looks simmilar, but not exact, i emailed him to see if it would work,
anyone have a used rt valve cover??? r they the same as an se?? exept for being metal and not plastic???
Old Jan 3, 2008 | 10:23 AM
NHARINTON's Avatar
NHARINTON
99% sure the r/t will fit..... the first gen the PVC is cominng out at a diffrent place... but other then that it looks like it would fit.... not sure tho [/align]
Old Jan 3, 2008 | 12:30 PM
Andpto's Avatar
Andpto
The first gen works and its actually better becasue the pcv valve is in a better location so you dont get the oil build up in the intake. The R/T works too its the exactly the same as the reg 2.0l
Old Jan 3, 2008 | 12:35 PM
dtjackten's Avatar
dtjackten
thanks, i am buying the indy manifold now so maybe later this winter i will get my hands on the valve cover.....
Old Jan 9, 2008 | 10:36 AM
NeonOn19s's Avatar
NeonOn19s
DJ-
I think that there is a guy on neons.org Jeff(something) on the vendor/group buys does powercoating, he states that he has a Chrome finish power that might look good. He is located in Michigan. I've seen his work and I"m sending him an extra valve cover to do.. He has all the equipment to do it. I would remove the coating on the vavle cover before you send it to him (aircraft paint remover works) If not he can sand blast it, but he will charge you for it.
Old Jan 9, 2008 | 10:41 AM
dtjackten's Avatar
dtjackten
thanks neonon19s
