for 03neonrt
Old Jan 27, 2008 | 11:58 PM
Dorin_82's Avatar
Dorin_82
Default for 03neonrt
i just checked out yourpicture gallery, i see that u have the prokit. i'm having a hard time deciding between prokit and sportline. the reason is that i also want to level it, not just drop it, and the sportline does that. does the prokit do that also? level it? or u just got some heavy stuff in da trunk? and how much did it go down with the pro? thanks.
Old Jan 28, 2008 | 12:13 AM
Yako's Avatar
Yako
Default RE: for 03neonrt
im sure he will tell u to go for the prokit, it already is a pain as it is, would recomend the sportline only if u didnt drive ur car at all, and u only had it for shows and taking it to the track and stuff, as a daily driver, leave it stock or get some mopar springs to drop u only an inch
Old Jan 28, 2008 | 03:00 PM
spikeymikey87's Avatar
spikeymikey87
go for prolines if you want eibach...i would suggest tokicos though
Old Jan 28, 2008 | 03:22 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i have sportlines, and they do not leval the car, just slam it..... u will still have the stock rake of the neon.... (front will be lower than the rear) if that is what u mean by leval it..... i honestly like the sport lines, but i do not drive my car year round.... but i do take it on some long trips and i really do not see a problem with them.....
Old Jan 28, 2008 | 04:11 PM
spikeymikey87
tokicos level it
Old Jan 28, 2008 | 04:27 PM
neon03se's Avatar
neon03se
ORIGINAL: spikeymikey87
tokicos level it
do they sell tokico springs alone? how much was your combo set, 400?
Old Jan 28, 2008 | 06:17 PM
03neonRT's Avatar
03neonRT
I would recommend the Prokit over the Sportlines for daily driving, simply because with the Sportlines you feel every single imperfection in the road, and I'm not exagerating at all. The Prokit makes the car sit compeltely level, however, the rear wheel gap is less (see my pictures) because stock the rear of the car sits higher then the front. If the wheel gap were equal then the back of the car would still sit higher then the front...
Thats my $0.02...
Old Jan 28, 2008 | 09:49 PM
Dorin_82's Avatar
Dorin_82
thk guys. i'll let you know what i got and after i'll put them on , i'll upload some picks. thanks again
Old Jan 29, 2008 | 06:10 PM
AirWolf's Avatar
AirWolf
I might be going with the prokit off of ebay . I like the drop and with the tokiko blues for the struts should be a nicer drop .
Old Jan 29, 2008 | 07:14 PM
srtgtr34's Avatar
srtgtr34
I thought you said that your neon was lowered?
