exhaust
Old Jan 29, 2008 | 02:06 PM
pacmansxt04's Avatar
pacmansxt04
Default exhaust
if iwould roll wit a srt turbo. http://www.horsepowerfreaks.com/pric.../SRT-4_Upgrade.
would i have 2 get an exhaust for a srt?
Old Jan 29, 2008 | 02:10 PM
neon03se's Avatar
neon03se
Default RE: exhaust
i dont think its that easy or else everyone would have that kit........and no it doesn't have to be the srt exhaust
Old Jan 29, 2008 | 02:33 PM
Sawhiskey's Avatar
Sawhiskey
Default RE: exhaust
That kit wont get you anywhere, you need more **** then that. Plus that turbo is too big. But, neon03se is right about the exhaust.
Old Jan 29, 2008 | 03:18 PM
srtgtr34's Avatar
srtgtr34
Default RE: exhaust
yeah they are rite you need to buy more stuff like a new engine computer since its a regular neon, and the turbo is made for a car that already has the srt4 turbo installed. Not saying it can't be done but it will cost some $$$$.
Old Jan 29, 2008 | 03:59 PM
GrApHite03's Avatar
GrApHite03
Default RE: exhaust
That kit would work if you had a mattdog adapter plate. The other posters are correct, there will be alot more parts to be had.
Intercooler
IC Piping
Clutch
Return and Feed lines for oil and coolant
fuel pump
injectors
regulators
return line
fittings
etc...
The turbo is technically not too big, but low boost will get you close to your internal power limit. 200whp turbo can be had with the stock ecu. i've done. 219whp / 244wtq stock internals and stock ecu
Old Jan 29, 2008 | 05:16 PM
srtgtr34's Avatar
srtgtr34
Default RE: exhaust
ORIGINAL: GrApHite03
Intercooler
IC Piping
Clutch
fuel pump
injectors
regulators
return line
fittings
etc...
Are you going to keep it at 219hp?, or are you going to get the forged internals and pcm soon to get a bit more?
Old Jan 29, 2008 | 05:18 PM
Adionik's Avatar
Adionik
Default RE: exhaust
He doesn't have that car anymore
Old Jan 29, 2008 | 05:25 PM
GrApHite03's Avatar
GrApHite03
Default RE: exhaust
ORIGINAL: Adionik
correct. sold it and moved to hawaii. car was fun and i never had a problem with it (boosted or N/A), but what i learned is that i will never mod a neon again.
