grinding tranny
Old Jan 26, 2008 | 03:49 AM
noen_newbe's Avatar
noen_newbe
Default grinding tranny
hey guys me again,
i started noticeing that my tranny makes a grinding noise
it sorta sounds like when you forget to put that plastic liner back and you drive it makes a plastic asphalt grinding noise?
well it does it when i start the car and its cold and i drive off it only happends when its cold and in 1 and 2 gear only?
also when the car is cold it is xtreamly hard to put it in secound gear and or back into 1st
weird isnt it ?
Old Jan 26, 2008 | 08:27 AM
bone33's Avatar
bone33
Default RE: grinding tranny
bleed your clutch hydraulics. could be air in the lines.
Old Jan 26, 2008 | 11:43 AM
noen_newbe's Avatar
noen_newbe
is that a two person job and is there a how to some where i dont know about?
Old Jan 26, 2008 | 03:54 PM
bone33's Avatar
bone33
what year do you have?
Old Jan 26, 2008 | 11:55 PM
Izero's Avatar
Izero
might be time for a tranny flush.... change the fluid
Old Jan 27, 2008 | 03:21 AM
noen_newbe's Avatar
noen_newbe
its an 01
thing is that i also just switch the cclutch not even a month ago and i only used lucas oil didnt put nothing else you think thats wat it is? i was soppoed to mix it wiht trans fluid
Old Jan 27, 2008 | 10:46 AM
Undesolved's Avatar
Undesolved
ATF+4
Old Jan 27, 2008 | 11:08 AM
bone33's Avatar
bone33
ORIGINAL: noen_newbe
its an 01
the lubricant should be ATF+4 yanno, all those High Performance products sold are serious overkill for a stock neon.
Old Jan 27, 2008 | 09:55 PM
Izero's Avatar
Izero
and they can be way too thick when cold and way too thin when hot... you gotta use the mopar ATF+4 trans fluid.....
Old Jan 27, 2008 | 10:24 PM
noen_newbe's Avatar
noen_newbe
so i gatta drain the trans? again how do i fill it again then?
and i have a manual so why would i atf+4? when the car warms up i shift reall nice except some times i mis third donno why its like the clutch didnt disengage right like if i didnt shift right for example like if i put the clutch down and let go before i put it in gear it will make that grinding sound.
i just dont wanna break somethign cause right now im in a huge bind and my car is the only way to get money as i am delivering pizza
