Camshaft sensor
RE: Camshaft sensor
If you have an autozone around I would go there and get your sensor only cost me 40bucks and they can show you where its located its in a pretty tricky spot. Took my brother and me an hr to do but it was very hot out and the sensor was pretty hot so if you do it now wont be so long toputon.
RE: Camshaft sensor
The camshaft sensor is located on the right side of the cylionder head just below the valve cover. Its held in place by four screws, and they're 10mm I think...it should take a whole ten minutes to remove the old one and install the new one. When I replaced mine, I think it cost like $13 at Autozone.
RE: Camshaft sensor
http://www.autozone.com/addVehicleId...leSelected.htm $30 at autozone, but check around at some of the smaller auto parts stores, usually you can get it cheaper from them.
Mat
Mat
Trending Topics
RE: Camshaft sensor
ORIGINAL: bone33
how long can you drive with a broken CPS? what will happen if i do?
RE: Camshaft sensor
ORIGINAL: 03neonRT
Any number of things could happen, from very rough idle, to sluggish acceleration, to being stuck in "limp mode" (the computer doesnt allow you to rev over 3k and its very jerky under 3k), among other things. Depends on how badly the sensor has malfunctioned. The sensor itself doesnt control the cam in any way, its just a sensor the computer uses to see where the camshaft is during its rotation, and then it dicatates A/Fr's and other factor sfrom that and other data.
ORIGINAL: bone33
