by the way....timming belt
Old Feb 23, 2008 | 12:16 AM
Adionik's Avatar
Adionik
Default RE: by the way....timming belt
ORIGINAL: Kalevra
HAHAHAHA!! Adoink got his *** handed to him!!
That was hardly a burn Kalevra
Old Feb 23, 2008 | 12:22 AM
AirWolf's Avatar
AirWolf
Lucky me when my husband had his little accident in my sxt she got her timing belt replaced with some other belts back in july . Mines a 2004 now with almost 111,00 miles on her.
Old Feb 23, 2008 | 09:01 AM
Jr. Mechanic's Avatar
Jr. Mechanic
I am partial to the goodyear gatorback timing belts. They are awesome belts and only cost $30 bucks from advance auto parts.
Old Feb 24, 2008 | 12:49 PM
lblackneon's Avatar
lblackneon
It's about 60k on the SRT-4. You should change your timing belt on the 2.0 Neons around 90k.
Old Feb 24, 2008 | 10:13 PM
01neon01's Avatar
01neon01
i went just past 100k when my water pump gave out. but while your changing the timing belt and water pump you might as well get a new udp while your at it .
Old Feb 24, 2008 | 11:19 PM
Dorin_82's Avatar
Dorin_82
ORIGINAL: 01neon01
ok, what's a udp?
Old Feb 24, 2008 | 11:21 PM
Jr. Mechanic
UDP= under drive pulley, it replaces the stock crank pulley and saves a few pounds off the crank gaining a few HP.
Old Feb 24, 2008 | 11:57 PM
Adionik's Avatar
Adionik
It's what i'm doing right now and is being a royal pain in the *** to get the stock pulley off.
The Chrysler insert is just a tad too small so i'm having to fabricate a longer "rod"
Old Feb 25, 2008 | 12:08 AM
Dorin_82's Avatar
Dorin_82
ORIGINAL: Jr. Mechanic
ok, did a little research, definitely will do . are the ones on e-bay any good? 200$ is a little to much for unorthodox racing.
Old Feb 25, 2008 | 12:16 AM
contagious19's Avatar
contagious19
im going to change my cam to a mag cam when i do my timing belt and waterpump. im at 99340 miles so i should be savin up
