CAI Question
Old Feb 29, 2008 | 10:37 PM
Mat00ES's Avatar
Mat00ES
Default RE: CAI Question
Just watch out, I bought a "CAI" and it turned out it was a short ram.
Mat
Old Feb 29, 2008 | 11:04 PM
fjlover's Avatar
fjlover
Well the blue cai doesn't look like a short ram but i'll keep an eye out thanks mat.
Old Feb 29, 2008 | 11:50 PM
Mat00ES's Avatar
Mat00ES
I didn't even look at the links, but yea they both look like actual CAI's.
Mat
Old Mar 1, 2008 | 07:22 AM
fjlover's Avatar
fjlover
Is it pretty easy to install?
Old Mar 1, 2008 | 11:18 AM
03neonRT's Avatar
03neonRT
ORIGINAL: fjlover
Installation Instructions:
1.) Disconnect the negative battery cable.
2.) Remove the air temperature sensor from the stock intake tube.
3.) Remove the wire loom from the retaining clips on the side of the stock air box.
4.) Loosen and remove the five airbox retaining bolts then remove the airbox lid.
5.) Remove stock air filter.
6.) Remove intake tube from fender well.
7.) Remove the four throttle body retaining bolts from airbox (these bolts will be re-used).
8.) Remove the crankcase vent hose from the air box.
9.) Remove the bolt and nut that secures the airbox to the vehicle then remove the airbox (this bolt and nut will be reused).
10.) Break lug nuts loose, then jack up the drivers side of the vehicle (remember to support with jackstands).
11.) Using a T-20 wrench, remove the two screws that retain the inner fender valance to the fender. Then remove the two push pins and move fender valance away to allow access into the fender well.
12.) Remove the two bolts that retain the resonator to the fender well then remove the resonator.
13.) Remove thebattery tray mounting bolt (this will be reused).
14.) Using the four bolts that were removed in Step #7, secure the two provided throttle body brackets to the throttle body.
15.) Using the battery tray mounting bolt that was removed in step #13, mount the throttle body bracket to the battery tray.
16.) Using the stock bolt removed instep #9, secure the throttle body bracket to the stock airbox mount.
17.) Install the supplied silicone hose and hose clamps to the throttle body and tighten throttle body hose clamp. Then, install the supplied edge trim to the resonator fender well hole. Finaly, install the larger grommet into the intake tube bracket and the smaller grommet into the intake tube.
18.) Slide the intake tube down the resonator hole then insert the other end into the throttle body silicone clamp.
19.) Align the intake tube braket to the stock airbox mount. Using the supplied nut, tighten the intake bracket to the stock mounting stud.
20.) Install the air temp sensor into the rubber grommet on the intake tube.
21.) Using the supplied silicone hose, attach one end to the intake tube and the other end to the crankcase vent tube.
22.) Install the hose calmp onto the air filter and attach to the intake tube inside the fender well.
*Note* Make sure everything is tight!
23.) Remount inner fender well valance, tire, and reconnect negative batter cable in reverse order.
**These instructions were writen for the K&N Typhoon Cold Air Intake and may vary depending on CAI brand**
Old Mar 1, 2008 | 11:56 AM
AirWolf's Avatar
AirWolf
I love my sxts ebay intake like now she has a k&n filter on and during show season I have a cf filter on. Never had any problems with her ebay intake its been on for almost 4yrs.
Old Mar 2, 2008 | 02:57 AM
fjlover's Avatar
fjlover
Thanks guys for all the answers, you guys are the best.
