ANOTHER VERY VERY IMPORTANT MS Q!!!!
Old Mar 4, 2008 | 03:44 PM
GrApHite03's Avatar
GrApHite03
Default RE: ANOTHER VERY VERY IMPORTANT MS Q!!!!
keep in mind... If you replace the MS with the stock control when you go to get inspected, how is the stock computer going to react with bigger injectors and other mods you may have. Both o2 sensors connected? etc...
I'm so glad i moved to Hawaii. No emissions here, just a visual safety.
Old Mar 4, 2008 | 03:56 PM
spikeymikey87's Avatar
spikeymikey87
dummy coil pack and injectors = no cel
Old Mar 4, 2008 | 05:09 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: spikeymikey87
what about fuel control CELs? Are you running any CELs now with your set-up?
Old Mar 4, 2008 | 09:12 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i guess i do not understand how the dummy coil pack works mike????? can u explain alittle more??? i am kinda slow with the electrical part of this ****.... lol, i know how everything works but that apparently?????????? i looked at ur pics on ur post, but i guess i do not understand on how u get that to work with no check engine lights, u HAVE to have monitors on ur stock ecu to pass in ny state...... and with an ms i do not see how it will ever have the same monitors as a stock ecu, and run off of the obd2 plug for emisson test.....
Old Mar 5, 2008 | 02:38 PM
dtjackten's Avatar
dtjackten
well on diyautotune.com i found ms for 297.75 that includes all i will need...... i am not sure how people r spending in the upwards of 600 dollars to get the ms?????????
Old Mar 5, 2008 | 02:56 PM
dtjackten's Avatar
dtjackten
https://www.diyautotune.com/catalog/shopping_cart.php
accually my number was off did not have the map sencor with it......
Old Mar 5, 2008 | 02:57 PM
dtjackten's Avatar
dtjackten
Remove
Product(s)
Qty.
Price Per.
Total
MegaSquirt-I Programmable EFI System PCB3.0 - UnAssembled Kit
$187.00
$187.00
12' MegaSquirt Wiring Harness (MS1 / MS2 Ready)
$65.00
$65.00
GM Closed Element CLT / IAT Sensor with Pigtail
$17.75
$17.75
MapDaddy 4 Bar MAP Sensor with Barometric Correction
$65.00
$65.00
PCBv3 and v2.2 -- VB921 High Current Ignition Coil Driver Kit
$9.50
$9.50
Sub-Total: $344.25
Continue Shopping[/align]
Checkout[/align]
Shipping Options:
Please Log In, to display your personal shipping costs.
ITEMS:5-Weight:3.85lbs
Country:Please SelectUnited StatesAfghanistanAlbaniaAlgeriaAmerican SamoaAndorraAngolaAnguillaAntarcticaAntigua and BarbudaArgentinaArmeniaArubaAustraliaAustriaAzerba ijanBahamasBahrainBangladeshBarbadosBelarusBelgium BelizeBeninBermudaBhutanBoliviaBosnia and HerzegowinaBotswanaBouvet IslandBrazilBritish Indian Ocean TerritoryBrunei DarussalamBulgariaBurkina FasoBurundiCambodiaCameroonCanadaCape VerdeCayman IslandsCentral African RepublicChadChileChinaChristmas IslandCocos (Keeling) IslandsColombiaComorosCongoCook IslandsCosta RicaCote D'IvoireCroatiaCubaCyprusCzech RepublicDenmarkDjiboutiDominicaDominican RepublicEast TimorEcuadorEgyptEl SalvadorEquatorial GuineaEritreaEstoniaEthiopiaFalkland Islands (Malvinas)Faroe IslandsFijiFinlandFranceFrance, MetropolitanFrench GuianaFrench PolynesiaFrench Southern TerritoriesGabonGambiaGeorgiaGermanyGhanaGibraltar GreeceGreenlandGrenadaGuadeloupeGuamGuatemalaGuine aGuinea-bissauGuyanaHaitiHeard and Mc Donald IslandsHondurasHong KongHungaryIcelandIndiaIndonesiaIran (Islamic Republic of)IraqIrelandIsraelItalyJamaicaJapanJordanKazakhs tanKenyaKiribatiKorea, Democratic People's Republic ofKorea, Republic ofKuwaitKyrgyzstanLao People's Democratic RepublicLatviaLebanonLesothoLiberiaLibyan Arab JamahiriyaLiechtensteinLithuaniaLuxembourgMacauMac edonia, The Former Yugoslav Republic ofMadagascarMalawiMalaysiaMaldivesMaliMaltaMarshal l IslandsMartiniqueMauritaniaMauritiusMayotteMexicoM icronesia, Federated States ofMoldova, Republic ofMonacoMongoliaMontserratMoroccoMozambiqueMyanmar NamibiaNauruNepalNetherlandsNetherlands AntillesNew CaledoniaNew ZealandNicaraguaNigerNigeriaNiueNorfolk IslandNorthern Mariana IslandsNorwayOmanPakistanPalauPanamaPapua New GuineaParaguayPeruPhilippinesPitcairnPolandPortuga lQatarReunionRomaniaRussian FederationRwandaSaint Kitts and NevisSaint LuciaSaint Vincent and the GrenadinesSamoaSan MarinoSao Tome and PrincipeSaudi ArabiaSenegalSeychellesSierra LeoneSingaporeSlovakia (Slovak Republic)SloveniaSolomon IslandsSomaliaSouth AfricaSouth Georgia and the South Sandwich IslandsSpainSri LankaSt. HelenaSt. Pierre and MiquelonSudanSurinameSvalbard and Jan Mayen IslandsSwazilandSwedenSwitzerlandSyrian Arab RepublicTaiwanTajikistanTanzania, United Republic ofThailandTogoTokelauTongaTrinidad and TobagoTunisiaTurkeyTurkmenistanTurks and Caicos IslandsTuvaluUgandaUkraineUnited Arab EmiratesUnited KingdomUnited States Minor Outlying IslandsUruguayUzbekistanVanuatuVatican City State (Holy See)VenezuelaViet NamVirgin Islands (British)Virgin Islands (U.S.)Wallis and Futuna IslandsWestern SaharaYemenYugoslaviaZaireZambiaZimbabwe
Zip Code:Recalculate
Shipping Methods:
Rates:
United States Postal Service (1 x 4.46lbs)(EXPRESS (1 - 2 Days))
$33.20
United States Postal Service (1 x 4.46lbs)(PRIORITY (2 - 3 Days))
$8.80
my link did not work here is what was in my cart......
Old Mar 6, 2008 | 10:43 AM
dtjackten's Avatar
dtjackten
alright, i have NO check engine lights on when i pulled the car into the garage... with my safc, but it does not tune enough for my liking... as far as o2 sensors both r there, then my wideband is hooked to a different o2 bung so i will be fine with o2 codes.... i guess i will have to get it, and just try it.... i guess no one really has the answers i need......[:@] i thank u all for the help though
Old Mar 6, 2008 | 12:38 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: dtjackten
I didn't see any other question other than if you will get a code. The answer is you will. I did see a question asking why people pay upwards of $600 on megasquirt. I don't have the answer to that. When i was going to buy i was going to use the same company you posted.
I also had no codes when i used a SAFCII to boost my 03 NGC.
Old Mar 6, 2008 | 02:25 PM
dtjackten's Avatar
dtjackten
thanks graphite, but all i am looking for is can i take the ms and just unplug it from the back and plug in my stock ecu??? or will i have to rewire it all back up every time???? that is the biggest question i have really?? i just want to see how much work this is goin to be every year to just get it inspected??????????????????
and do i have everything in my shoppin cart i will need to do the ms??????
and mike if u get a sec can u explain how the dumby coil pack works?? but just because the check engine light goes out it does not mean it will pass in ny state.... all the monitors have to be "ready" and i dont think the ms has the capability of setting the correct monitors........
thanks again graphite!!!!!
