Installing a tach??
Old Jul 14, 2010 | 11:11 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
if u get a GOOD aftermarket tach with different cylinder ratings such as 2,4,6,8 u will not need a tach adaptor... the neon pcm only shows two cylinders firing because it reads 2 cylinder per curcit. so if u get a tach with a 2 cyl. rating u will not need anything to have it run correctly. but if u only have a 4 cylinder rating it will read HALF of your accual rpms.
Old Jul 14, 2010 | 11:42 AM
bkennedy1289's Avatar
bkennedy1289
ok thank you, well mine has 4,6, and 8 cyl... would that mean that I need the adapter(or get another tach)? cause I have a friend that would buy it off of me and I could get another one(a better one).
Old Jul 14, 2010 | 12:01 PM
bkennedy1289
*update* So I need to get the adapter or a new tach, wiring through the pcm with a sunpro is impossible.
Source: Sunpro tech service
Old Jul 15, 2010 | 02:54 PM
dtjackten's Avatar
dtjackten
^ that is correct.... my sunpro tach was kick ***, but it had a 2 cylinder rating on the back, so at the flick of a switch it was reading correctly. i would say get a tach with a 2 cylinder rating, unless u love the tach u have so much then spend another 60-80 dollars and get an adaptor.
