SOHC Engines Mods for SUPERCHARGER ?
Old Apr 25, 2008 | 07:51 PM
willyvenge's Avatar
willyvenge
Default RE: SOHC Engines Mods for SUPERCHARGER ?
Although superchargers do take power to make power, the gain you get still balances it out. Here's a little bit better of a link than the others that I posted.
http://en.wikipedia.org/wiki/Supercharger
I wouldn't say it wouldn't be worth it, especially if your looking for more low end power or a little bit easier installation... well, after you get the custom intake and brackets made, which really wouldn't be hard. The battle between supercharger and turbo will rage on forever. It all comes down to preference really.
Old Apr 26, 2008 | 01:45 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
So its pretty much split on yah or nay.
Old Apr 26, 2008 | 01:56 PM
03neonRT's Avatar
03neonRT
The only way to add a supercharger to a 2.0 Neon is to totally remove the AC compressor, and then custom make all the brackets, plumbing, etc, and of course, pick which supercharger you want to go with.
So, with all that work said and done, why not just use the insanely more proven method of forced induction on the Neon, which is a turbocharger?
Old Aug 29, 2020 | 12:32 AM
Jeff Good's Avatar
Jeff Good
I have a Eaton m45 on my 2004 sxt 2.0 and it was a pretty simple setup to Fab up and puts down a instant 8 pounds right off idle no waiting for a turbo to spool
Old Nov 11, 2021 | 04:41 PM
teano32's Avatar
teano32
Default Supercharger i
what did you do for the intake,intakehis the neon the gas the sc bolted to the IM correct?... tell me how you did that, that's exactly how I'm seeing my sc up, without custom building the intake altogether, what did u do
Old Nov 12, 2021 | 09:52 PM
Jeff Good's Avatar
Jeff Good
Default Simple
All you have to do is unbolt the AC condenser then you make a custom plate to bolt to m45 to it and you got to make a top hat for the blower for a inlet and outlet then pipe it to a intercooler and go from there nice pipe a bov big tb a nice intake manifold u know the works
Old Nov 12, 2021 | 10:01 PM
teano32's Avatar
teano32
Did you use the acr upper/lower plenum to bolt the sc to? What Im did u use for ur project?
