hyper voltage system and grounding system
Old Apr 25, 2008 | 04:42 PM
inthewerks's Avatar
inthewerks
Default hyper voltage system and grounding system
http://cgi.ebay.com/ebaymotors/Groun...QQcmdZViewItem does anyone have this or something similar?? is there a noticed performance gain from this or is it more of an engine dress up thing??
Old Apr 25, 2008 | 06:38 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Default RE: hyper voltage system and grounding system
Thats alot of money to ship some wires. You should read up on that. I guess some of what they say could be true.
Old Apr 25, 2008 | 06:39 PM
ewetho's Avatar
ewetho
Extra ground wires have been shown to increase HP a touch but not much. However every little bit can an does help. Lots of extra ground is a good thing.
Kind of a cool kit but not necessarily a quality kit.
Voltage regulation is popular in stereo application just to limit distortion and headlight flashing. Caps do this to some extent too. But for High performance application it is cool for like the Megasquirt system where you tun everything at one voltage. No 12.5 to 14.7 volts or what not, it is always the same and provides some of the benefits of Caps as well.
Old Apr 25, 2008 | 09:28 PM
KARR's Avatar
KARR
So for a 2 12 sub system what would be better those wires or those caps?
Old Apr 26, 2008 | 12:30 AM
inthewerks's Avatar
inthewerks
i think im gonna get them anyways. its not too expensive incase they dont add any power but at least my engine bay will look better and maybe a little more intimidating. ill post up some pics after i receive and install this kit.
Old Apr 26, 2008 | 12:55 AM
Caraudioholic24's Avatar
Caraudioholic24
to be totally honest with you guys, caps are somewhat junk. For the money you should buy a optima yellow top under the hood and one for the trunk. The yellow top (or equivelent)will have like 6 of those caps in it for the price your going to pay for one. I will be running 3 yellow tops total in my neon 1 for the car and 2 for music. That will help regulate your voltage as well as grounding your engine bay and frame. Just some food for thought
Old Apr 26, 2008 | 02:17 AM
inthewerks's Avatar
inthewerks
yeah but what does three yellowtop optima batteries weigh?? like 120 pounds or something close to it. and the two you will use for the audio.........are they gonna run off your alternator also or you gonna charge them every night? and if you do run three batteries off of one alternator, how long is that alternator going to last? just my two cents.
Old Apr 26, 2008 | 12:43 PM
KARR's Avatar
KARR
Good point about the charging of the batteries. Here it says at Autozone the batteries weigh 36.4lbs.
http://www.autozone.com/R,APP333911/...ductDetail.htm
Those batteries areny cheap. Thats over $600 for three of them.
Old Apr 26, 2008 | 01:20 PM
NeonOn19s's Avatar
NeonOn19s
ORIGINAL: inthewerks
Actually I have the SUN Automotive Hyper Voltage system and the Hyper Grounging system. With having a audio system I did notice that my voltage is more stable from the grounding and voltage system... I paid a lot more for mine 4 years ago.
Old Apr 26, 2008 | 01:47 PM
KARR's Avatar
KARR
So that kit is worth it if you have a sound system? How hard/easy was it to install?
