subwoofer issuses
Old May 5, 2008 | 01:42 AM
  #31
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Default RE: subwoofer issuses
Good point. I asked him where his Amp was mounted and if its getting enuff air. Dont turn the bass down. You can never have enuff bass. Joking. For real I love bass.
Old May 5, 2008 | 01:45 AM
  #32
Baddog44's Avatar
Baddog44
ya well that is also a common problem when amps cut off as well
Old May 5, 2008 | 11:05 AM
  #33
night709's Avatar
night709
The amp sits on the back seat when it is folded down.
Old May 5, 2008 | 03:35 PM
  #34
Baddog44's Avatar
Baddog44
well check how hot it gets
Old May 5, 2008 | 05:46 PM
  #35
night709's Avatar
night709
It probably gets pretty hot.
Old May 5, 2008 | 05:53 PM
  #36
KARR's Avatar
KARR
The Amp needs more air. Try it with your backseat down to expose your Amp and see if it still cuts off. Also test how hot the Amp is before the backseat is down and when its down.
Old May 6, 2008 | 05:51 PM
  #37
night709's Avatar
night709
My backseat always sits down other wise my carpet that is above the rear speakers start to rattle against the back window. You can set your hand on the amp for a few seconds then it gets a little to hot to do so.
Old May 6, 2008 | 06:02 PM
  #38
Jaybird2089's Avatar
Jaybird2089
I'm not sure on this but i don't think you should have two wires going into the remote power input. Mine only has one comming from my head unit.
Old May 7, 2008 | 09:47 AM
  #39
KARR's Avatar
KARR
Yeah I was wondering about that. ^^^
Old May 7, 2008 | 02:40 PM
  #40
Jaybird2089
I would just double check all the wiring again. I think you have an extra remote wire that is comming from your cap. I don't think you need one going to your cap. anyways, it should turn on when the amp tries to draw power from it.
And like they said earlier check your grounding wires. You should have one coming from your cap that is the same size as your positive cable comming from the battery and also one that is gounding your amp.
