turbo
Old Jan 11, 2005 | 01:58 AM
dirtrider222's Avatar
dirtrider222
Default turbo
hi i have a 2000 dodge neon... i was wondering if i put the turbo kit on from modern performance, the 16g turbo, and ran a low boost, like 6psi will it dramatically reduce the life of my motor, and with such a low psi and stock compression will there be a great power difference.
thanks joe
Old Jan 11, 2005 | 02:06 AM
casper's Avatar
casper
Default RE: turbo
If you are getting either the hahns racecraft or chill factory kits, then yes it will give you a 75-100 ho increase, thats a guess. It will not affect engine life, however your right foot always on the gas cause you have a turbo and like to go fast will reduce engine life. You should do a cam and valve springs if you do the turbo. The lower end of the motor will handle about 300HP.
Old Jan 11, 2005 | 03:16 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: turbo
You can run 8psi on stock internals with a heavy foot with no problems. You should do a cam and valve springs though.
The Hahn Racecraft kits are built for stock internals so you will be ok.
I do however suggest reading Maximum Boost by Corky Bell.
Old Jan 11, 2005 | 11:03 AM
dirtrider222
Default RE: turbo
thanks a lot
joe
Old Jan 11, 2005 | 11:06 AM
dirtrider222
Default RE: turbo
should i do the valve springs and cam before getting the turbo kit or should i get the turbo and just do the cam and springs sooon after, and if any one has bought the chilled turbo kit please let me know how you like it, and what were you power increases.
thanks
joe
Old Jan 11, 2005 | 09:39 PM
Cr@zy Squ33
Default RE: turbo
You should do the cam and springs when you do the turbo.
And what do you mean by chilled kit? Do you mean intercooled?
Old Jan 12, 2005 | 01:22 AM
dirtrider222
Default RE: turbo
sorry i ment chill factory kit, can you give me a link to the maximum boost page to read
thanks
Old Jan 12, 2005 | 01:37 AM
Cr@zy Squ33
Default RE: turbo
Chill Factory is a little better.
Go to the book store and tell them you want to order Maximum Boost by Corky Bell.
Old Jan 12, 2005 | 04:25 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: turbo
I've seen it at Barnes and Noble in the automotive section, if you have one of those. I'm sure your local bookstore has it, or you could find it online as well.
