preformance exhaust/ gas nilage
Old May 2, 2008 | 03:23 PM
neon riders's Avatar
neon riders
Default preformance exhaust/ gas nilage
i had a 4 1/2" prefomace exhaustinstalled and i was getting about 32 miles but now im getting about 25to the gallon with an air intake system is there any thing i can add on exhaust to get my milage back
[IMG]local://upfiles/88460/88FEB85B046B4434B05FF81847061C22.jpg[/IMG]
Old May 2, 2008 | 03:30 PM
contagious19's Avatar
contagious19
Default RE: preformance exhaust/ gas nilage
4.5 " exhaust is too big on ur car. ur definetly loosing bottom end and dat might b hurting u.
Old May 2, 2008 | 04:41 PM
neon riders
not shure if its a 4.5 or not but is a preformane exhaust
Old May 2, 2008 | 10:04 PM
Ghost Neon 2's Avatar
Ghost Neon 2
That more like the pipe on a semi. Who the hell told you to do that?! You need nothing ore than a 2.5, and that is not needed depending on what mods you have.
Old May 2, 2008 | 10:21 PM
inthewerks's Avatar
inthewerks
is it a 4.5 inch exhaust piped system or do you have a fart can muffler with a 4.5 inch outlet tip on it??
Old May 3, 2008 | 10:28 PM
neon riders
well the outside diameter of the muffler is 4.5 but not know the acutal size but guess its a normal exhaust that every one has
Old May 4, 2008 | 01:23 PM
Undesolved's Avatar
Undesolved
i'm hoping your inlet is <2.5 in. and your outlet is 4.5in. cause otherwise you've got too big
Old May 4, 2008 | 09:22 PM
neon riders
do believe its 2.5 in and 4.5 out and for the fuse its a numbered code p1648 wich means the oil sending unit is fried
Old May 5, 2008 | 03:23 AM
N30N's Avatar
N30N
the stock 02 es neon exhaust on mine was 2.25 in and out so i upped it to 2.5.everyone is right man with a 2.0 4 banger you dont need that.thats probably killing your gas.also try a restoration kit for your intake, they work great and make the filter look andperform like new...
Old May 5, 2008 | 09:29 PM
neon riders
its a brand new air intake kit only a couple days old,what about a heat shield for the intake?also what would u put on a 2.0
