Big?? Uh-oh... Need some help....
Old May 3, 2008 | 07:21 PM
Izero's Avatar
Izero
Default Big?? Uh-oh... Need some help....
Ok so i was putting a powercoated valve cover on today and as my brother was tightening up the valve cover bolts... he broke one of the bolts.... it isnt a corner bolt but he still snaped the thing pretty good....
1) how serious of a problem is this? (can i still drive here and there...? i did put extra RTV gasket maker all around the edge of the valve cover and all that)
2) whats the part # for the valve cover bolts as im gonna need to get a new one...(might pick up more than one if i can... just in case "muscles" (aka. my lil brother) takes his anger out on one of them again...)?
thanks guys
Old May 3, 2008 | 07:49 PM
MJND1990's Avatar
MJND1990
Default RE: Big?? Uh-oh... Need some help....
Im not sure what the number is for them. But you should pick up a Torque wrench while your out. The valve cover bolts are supposed to be torqued to 105 inch/lbs.
Old May 3, 2008 | 09:13 PM
inthewerks's Avatar
inthewerks
is the thread of the bolt still stuck in the cylinder head?? if so, go to ace hardware and they have a kit for around 20 bucks that comes with different sizes of these reverse drill bit things that actually will turn the bolt out for you so when you put a new one in, its no problem.
Old May 3, 2008 | 09:28 PM
Izero's Avatar
Izero
yea i have the channel lock or w/e its called... i just need a new bolt to put in there..... anyone know what the part # is or anything...?
Old May 4, 2008 | 03:01 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Just take one of the other matching bolts up to Home Depot and let them or you match it up on the nut and bolt chart. Simple problem simple solution.
Old May 4, 2008 | 05:27 PM
Izero's Avatar
Izero
yea but if i do that the bolt wont have the seat for the gasket that it comes with so ill be SOL in the gasket dept.... which could cause a leaking problem.....i just want to fix everything and not have to worry about all of it.........
Old May 4, 2008 | 06:08 PM
DouglasSXT's Avatar
DouglasSXT
You should be able to order a set of bolts from a auto place... If not there then a dealer would def be able to hook you up, It'll be more money but you'll have the right bolts...
Old May 4, 2008 | 06:09 PM
Izero's Avatar
Izero
yea... im gonna try a place around me... wish me luck.... if anyone has the part # from the dealer it might come in handy so post it up.....
Old May 4, 2008 | 08:18 PM
Freerider's Avatar
Freerider
No part numbers I can offer.... but you do need all seated, you do need all torqued properly.
So make sure you do that before you drive it.
Old May 4, 2008 | 08:56 PM
01neon01's Avatar
01neon01
just go to a pick a part or whatever junk yards there are in your area if you really need to get one and get it from another neon.
