LEAKY NEON!?!?
Old May 4, 2008 | 03:56 PM
00Neon89's Avatar
00Neon89
Default LEAKY NEON!?!?
Well i just got my first neon its an 2000 ES and whenever it rains the back floor is filled with water anyone else have this problem and if so do you know where its coming from it feels like somewhere under the seat..but im not sure anyone else have this problem,
Old May 4, 2008 | 05:24 PM
srtgtr34's Avatar
srtgtr34
Default RE: LEAKY NEON!?!?
I used to have this problem but, it mysteriously stoped.
It came in through the front door seal( mine was the drivers side front).
SO you should check your door seals.
Old May 4, 2008 | 05:43 PM
00Neon89's Avatar
00Neon89
yea its my drivers side and both passanger an driver side in the rear [:@]but yea ill go check them out right now
Old May 4, 2008 | 05:46 PM
Izero's Avatar
Izero
could be window seals/door seals or it could be the sun roof (if you have one that is)....prolly just a simple seal somewhere is all
Old May 5, 2008 | 12:24 AM
inthewerks's Avatar
inthewerks
i would also suggest a bad seal somewhere. you might also check to see if maybe one of your windows is bashed out or you can also check to see if there are any bullet holes in the roof or through the door or something. hope this helps.
Old May 5, 2008 | 12:42 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Those are good causes but not likely. Ill tell you exactly where its coming from go inside your trunk andpull upthe carpet by each brake light and feel for water. If you fing it let me know and I'll tell you the best surefire way of stopping it. Trust me I know.
Old May 5, 2008 | 05:23 PM
00Neon89's Avatar
00Neon89
yep i went into the trunk after pulling out the two pioneer 12's and amp there is water in the trunk so KARR best way to stop?
Old May 5, 2008 | 05:39 PM
KARR's Avatar
KARR
I replyed to your PM. Pm me back and let me know whats up.
Old Nov 2, 2008 | 11:37 PM
darthroush's Avatar
darthroush
Section Moderator
Anyone have the part numbers for the passenger taillight seal on the 03-05's? I found a puddle of water in my car today. Underneath the front passenger seat, rear passenger floor board, rear seat, trunk and the spare tire well. I can clearly see the water is coming in from the passenger taillight area. It is just completely blowing my mind how THAT much water got in there to where it flooded not only the truck area, but made it all the way into the cabin!!!! I hope it stops raining soon, GOD!!!
EDIT: Guess it couldn't hurt to just buy a new pair... Numbers por favor!!
Old Nov 3, 2008 | 12:11 AM
OhNo2.0's Avatar
OhNo2.0
Maybe you pissed someone off and they just happened to tap into a fire hydrant and point it at your taillight cause they knew, they really KNEW that they leaked and that that would really **** you off.
That's why you have so much water in your car...stop pissing people off who know how to use fire hydrants.
