Seafoam?
Old May 14, 2008 | 02:55 AM
Kalevra's Avatar
Kalevra
Default Seafoam?
Ok. I know how to do this. (kinda) 1/3 in PVC line, 1/3 in crank case. 1/3 in fuel. wait 10 minutes. start her up and let her run and take her for a high rev spin till it stops smoking then make a beeline to get the oil changed.
Now. what else needs to be replaced?
Old May 14, 2008 | 03:02 AM
Adionik's Avatar
Adionik
Default RE: Seafoam?
-Get 2 cans
-Don't pour ANY in the crankcase
-Pour 1 can in the gas tank with a fresh gas
-Pour 1 down the pcv line and let the car sit for ATLEAST 30 minutes
Ride it like you stole it
Putting it in the crankcase doesn't really do **** for performance and you will 100% need to change your oil after that. Either way if you're going to seafoam you'll need to change out your spark plugs as well.
Old May 14, 2008 | 03:04 AM
Kalevra's Avatar
Kalevra
isn't a full can down the PVC line abit much?
I need to change my oil anyway. so I dont see why not.
and recommended plugs?
Old May 14, 2008 | 03:12 AM
Adionik's Avatar
Adionik
Yeah that's kind of a lot LOL. But I think 1 tank in the gas really cleans **** up. It changed the exhaust tone on my bike and it ran a lot better afterwards. I didn't feel nearly the same in the neon but that's because it's a car. I'm sure the internals were cleaned up.
You do realize that after you put it in the crankcase you almost immediately have to get that **** out. It's like running an oil gunk remover.
I run the $2 plugs ngk or something at autozone....I change them every oil change so it doesn't really matter
Old May 14, 2008 | 03:16 AM
mat663's Avatar
mat663
oh, so you shouldnt change your oil and put the seafoam in and leave it there for another 3000 miles????
Kalevra's Avatar
Kalevra
I see. so can I get away with 1/2 in the PVC and 1/2 in the tank and nothing in the crank? Do I still need an oil change?
Old May 14, 2008 | 03:37 AM
Adionik's Avatar
Adionik
Nope, wouldn't need an oil change
But change the spark plugs
Old May 14, 2008 | 05:07 AM
Kalevra's Avatar
Kalevra
Ok. cool. now... where the hell is the PVC line I put it into?
Old May 14, 2008 | 07:12 AM
Mat00ES's Avatar
Mat00ES
Drivers side of the VC, Im pretty sure. So, I just did an oil change like 200 miles ago, I can still seafoam aslong as I put none in the crankcase and only replace my plugs?
Old May 14, 2008 | 09:02 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
How good is that Seafoam supposed to be?
