no low beam headlights
Changed the MFS this morning and the hi and low beams work but nowthe blinkers don't. The part number on the old switch is X671865AB (first digit/number unreadable)and the purchased part is 5073045. I'm not sure if the new part is a replacement number or not but the blinkers are inop.
The plug has some scoring/burned marksit as does the MSF so I'll end upreplacing the plug assembly also.It's all stock assembly and I haven't an idea of what's generating so much heat causing the parts to burn and fail.
I hope replacing the plugwill get everything working properly again.
Any ideas?
Any ideas?
