ABS????
ABS????
I might be getting a srt brake setup front and rear soon, but i have some questions first.
My car is not equiped with abs and the srt brakes do, so how does that work, do i just plug and play or is there a seperate module i would have to buy? If its possible i would like to have abs brakes. How can i get abs on my car?
Is it really worth upgrading the fronts to srt brakes?, i know the are just a tad bigger but is the improvement in braking that much better?
RE: ABS????
The physical SRT-4 brake parts should bolt up with no problem...they just wont have ABS. If you want ABS, you'll have to get the ABS module, cluster from a car with ABS, body harness from the SRT with ABS sensors, etc.
Your fine as long as the caliper is getting a boost signal from the cylinder...
So, it will be much easier to just swap in the SRT-4 front brakes and leave it non-ABS.
RE: ABS????
Dam that sounds like it would be a hassle to convert to abs.
Although i would like to get your opinion whether it is worth the money to upgrade the fronts to srt, i will do the rears but i'm unsure because if the increase in braking isn't that much, thats not worth sacraficing the abilty for me to drive this car in thewinter and to not be able put 15's on the front.
Thanks
Thanks
